SOURCE: BenQ MP610 password???
Hi, i have a problem with MP610 i lost password and i can give you the code num 22654 15072 7440 9690
SOURCE: Benq MP620c not recognized by RS232 PC (Win XP) COM1 connection
please try to switch your pc on first and then your projector-use fn(key) in conjunction with f4 or f5 or f6 or f7.
SOURCE: projector says out of range
The native resolution on the 6100 is 800x600. I have had it recognize 640x480 and 1024x768 though. Check your computer to make sure the resolution is 800x600. Also set the refresh rate at 60htz, if the refresh is too high it can give out of range errors.
SOURCE: BENQ PROJECTOR
Mine needed a "fan module" replaced. The part number is 60.J8613.011.
Cost was $60, plus $100 for labour.
SOURCE: I have a DLP Benq projector (not sure the model
go into the menu and reset the settings to factory default. after that, select computer again and see if it recognizes it. you may need to change the resolution to match the laptop.
