Door is hard to open and close
SOURCE: "Door Locked" Indicator Switch Faulty
You should access the lid switch (the switch is inside the machine main housing near the door frame) and to see whether it become loose or was broken. Good luck!
SOURCE: my front load Tromm LG
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
SOURCE: LG Tromm model WM2455HW front loader walks and
It should have adjustable feet with rubber pads to prevent it from walking.
SOURCE: My LG Tromm detergent door is stuck closed and I
Here's what I would do:
Take the two screws off the back plastic parts which are attached to the top cover. Leave the ones in that go into the cover, just remove the bottom one on each side.
Now, standing in front of the machine, use the palms of your hands to sharply push back the top cover (pushing on the right and left edge of the top). It only moves about two inches. Now, lift the cover off.
Use a flashing to try to see into the semi opaque dispenser to determine where the hang up is.
Drill a small hole in the top of the dispenser chamber to allow you to poke an object like a screw driver in to manuver the offending part of the dispenser, allowing removal of the dispenser drawer. Use a peice of foil duct tape to seal the hole you previously drilled.
SOURCE: i have LG ,Tromm washer
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
