Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look (((•))) Make sure its pressed on. There should be an option to "automatically connect" when it detects the network. Look for a checkbox. create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help click on the tools at the bottom of the drop down list will be internet options in the connections tab tick in the box never dial a connection below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them Power on the laptop computer and wait for the operating system to boot before proceeding. Right-click the wireless icon in the lower right corner of the desktop. From the pop-up menu select "Enable." This activates the wireless Internet options but it does not turn on the wireless receiver. Push down on the wireless button or wireless switch on the top of the keyboard. After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection. Right-click the wireless icon again. From the pull-up menu choose to view all available wireless networks in the area. A window appears with all the networks your computer receives some sort of signal from. Select the wireless network you want access to, type in the password (if required) and click "Connect." Momentarily the laptop computer connects to the Internet. you should be able to, it depends on the laptop, the os, the wireless adapter, and the settings . Click start Control Panel - Network Connections - right click on 'Wireless connection' (or similar) and click 'enable'. right click on the network in the bottom toolbar select open network sharing center you should have the options to either connect or disconnect or set up a network connection this will vary depending on your operating system Hope this helps. b>
<p>The HTC Touch Pro smartphone 2 is avaialble for T-Mobile and
Sprint subscribers, and uses the data network cell phone to connect to the
Internet. While the Internet connection is based on a strong 3G connection for
fast browsing, you can also activate the Wi-Fi device to connect to a wireless
network. Available Wi-Fi networks within range of the Touch Pro will be
displayed on the device are on the list of networks. Once connected, your
Internet speed is capable of data based on the strength of the wireless signal
to send. <br />
<p><br />
<p>1. Slide your finger on the "Home" screen to the
tab "Settings" appears. Play the "Communications" button. <br />
<p><br />
<p>2. Touch "Wi-Fi" on the phone screen, then hit the
wireless network is displayed in the "Discovered Networks" list. <br />
<p><br />
<p>3. Type the network security key using the onscreen
keyboard, and press "Done" for the network to connect. A wireless
signal appears at the top of your phone screen when connected to Wi-Fi network
successfully <br />
<p>4. Touch "Back" to return to the
"Communications" menu. <br />
<p><br />
<p>5. Play the "ON / OFF" in
"communication" from the menu for Wi-Fi off. It is important to turn
off the Wi-Fi functionality when not connected to a wireless network, because
this mode the battery is not on. <br />
<p>Apple's iPod device only with Internet capabilities, the
iPod Touch. Other versions of the device can only synchronize with a computer
full of music and video. The iPod Touch, however, can connect to wireless
Internet networks, where available. Bringing the Internet to your iPod Touch,
you need Wi-Fi settings to activate the device. Once you allow them, the iPod
Touch Wi-Fi settings will be available networks, you can connect to a tap of
the finger to detect. <br />
<p><br />
<p>1. Click the Settings icon on the home screen of the iPod
Touch. <br />
<p><br />
<p>2. Click Wi-Fi <br />
<p><br />
<p>3. Click "On". <br />
<p><br />
<p>4. Click a wireless network in the list that appears to
connect. <br />
Method 1: Check your local connections at network and sharing center, if there are two enabled or active networks. If there is two active networks, click on Local Area Connection Link (for windows 7) on one of the active networks and disable it. Now right click the internet icon on your taskbar and troubleshoot problem. If it doesn't resolve the problem, you will have an option to resolve the problem as Administrator.
Method 2: Go to local area connection status on an active network, click properties then double click on internet protocol version 4 and make sure that "Obtain an IP address automatically" and "Obtain DNS server address automatically" are checked then click OK.
If it doesn't solve your problem. Please contact me so that I can assist you more further.
Error 1106 is an indication that the Domain Name System (DNS) was unable to resolve.
Follow the steps to check the Internet connection:
1. Check the Network Connection.
1. Using the supplied remote, press the Home or Menu button.
2. Select Network Setup .
3. Select View Network Status .
4. Select Check Connection .
If any of the connection settings fail, verify that the TV is properly connected to an active Internet connection. Follow these steps, if the error continues to appear:
2. Unplug the TV and wait 60 seconds.
3. Power on and off all of the networking equipment, including the modem and router.
4. Allow the Networking equipment to reset after powering them of and on. Test that the connection is active by using a computer.
5. If the issue continues, wait and try viewing the content later.
Here are a few things to try: - Remove all the devices plugged into the netgear and leave only the TV and Internet connection - Swap the cable for the TV Internet connection - Try a different port on the netgear - Monitor the activity lights on the netgear
Are you still able to connect to netfix via a computer?
As the icons have increased in size that means ur screen resolution has changed
Goto desktop right click on desktop >> Properties >> settings tab now u will find the Screen Resolution adjust it according to ur requirement and u will find ur icon size small again ( if u increase the screen resolution)
For internet settings Create a New Connection Wizard or u can check from Network Connection whether ur Local Area Network is Enable or not.
