Should i replace inlet valve or could it be another issue leaking water with any different levels of water.
If you cannot see the water leaking from the inlet valves, check the seal just above the water pump located directly under the drum. I am in the midst of awaiting parts to fix this very thing on my FP GWL11. This leak is dripping water directly onto the motor, causing it to trip the circuit breaker during drain/spin cycles.
Note... I have also had to have the inlet valve assembly replaced as well as it was not opening to allow cold water to mix with the hot.
Hope this helps.
Not enough info given to answer properly. Where is the water leaking from? Can you see where it starts from?
