Can the fuel pump be removed without dropping the tank ?
Under the rear seat you should see it there make sure when you take it out that you are useing brass tools
Some cars yes and others not at all it really depends on the year make and model check the floor panels for an access door above where the tank is if it has one there should be a fairly easy access able spotaround the front of the trunk or under the rear seat
