Question about Refrigerators
Do i need special hinges to change this refrigerator from left hand door to right hand door?
Do I need special hinges to reverse this door from a left handed door to a right handed door?
  • Bailey's Appliance Service
    You would need a model umber to determine that. Most refrigerators have doors that change from left to right by swapping hinges and handles from one side to the other. A few model have specific hardware for right and left door applications. Then last but not least, there are a few models built left or right only without the ability to reverse the doors.
    A quick check of your Use and Care guide would explain door reversal.
  • 59 Answers
NO YOU USE THE SAME HINGES
Posted on Apr 29, 2009
6ya staff
SOURCE:
I have a Samsung refrigerator RL46WBSW. How can I reverse the direction of the door opening from left-right to right-left?
Most fridges are designed so that the door can be flipped to reverse the opening direction. Look where the hinges are now. Look on the other side of the opening. Are there mounting holes to accept the hinge bolts? If so, unbolt the door, flip it so the bottom is now the top, and re-attach the hinges and bolts.
If you lack mounting holes, the door likely cannot be flipped.
Mar 17, 2018 | Samsung Refrigerators
Need part number for left and right hinge clip(s).
You just swop the bottom and top hinges,remove the top hinge and install on other side on bottom, do reverse with bottom hinge ,if there is provision for the hinges to be swoped by means of threaded holes on the refrigerator and holes on the otherside of the door (left or right). Before you start see if its possible. Good luck,
Peter (S.A)
Jan 17, 2013 | Refrigerators
How do I change the door from left hand to right hand opening
on the top right hand side of the refrigerator you should see little screw cover caps,, also on the door and on the bottom of the door. remove these caps -- now remove the screws that hold the hinges for the door and just switch everything over to the other side. everything is a mirror image of the other side --- where there is a screw that holds the hinge on one side -- there will be a screw hole on the other side that is covered by a finish cap,,, same thing with the hinge pin hole. tighten everything up and use the finish caps to plug up the now exposed holes and there you go -- right hand opening door.
if you have any troubles -- just write me back here and I will do my best to walk you through it.
c...
Feb 03, 2011 | Kenmore 72912 / 72914 / 72919 Bottom...
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Changing Right Hand Door Fridge to Left hand door
This is a simple job remove both doors and switch them from left to right.You will have to remove the plugs from the holes where the hinge go be sure to adjust the gap between the doors and put the plugs back in the place where the old hinge screws were.
Hope this was helpful.
Sawdust46
Aug 19, 2009 | Refrigerators
How to reverse door on kelvinator fridge?
Im unable to look up htat particular model number for you, looks like my FRT18, which is made by the electrolux company, in which case, YES you can easily switch the door swing form one side to the ohter, whats on the left goes to teh righ and right to the left, not a problem
Jan 11, 2009 | Refrigerators
Reverse door
In my experince all refrigerator doors can be converted from right to left opening. Look carefully how the doors are hinged and look for the same arrangements on the other side of the refrigerator. They may have plastic blanks which can be removed with a screwdiver, but they will be there. Turn off the fridge while working on it. And make arrangements for your frozen food if necessary.
Ray
Nov 07, 2008 | Ovens
Change right hand door ,to left hand
Not sure with this model but most time you can and I'm sure this is no different, look at the screws holding the hinge bracket, there should be identical screw holes to match on the opposite side.
Aug 06, 2008 | Dometic RM2652 Refrigerator
Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Jun 25, 2008 | Kenmore 64702 Top Freezer Refrigerator
Refrigerators Logo
394 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
