SOURCE: Icemaker flap/door does not mechanically open
The description says you have an LG fridge? I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door. Let me know if you need more help. Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
SOURCE: ICe does not fall from KitchenAid KSCS25INSS00 Ice Dispener
remove the bottom tray that you sit your glass on, push down on the bottom of the trim arround the despenser, lift outward then upward on the trim panel, have a piece of duct tape handy to tape the panel out of your way to gain access to the assembly
SOURCE: GE Profile Arctica Side by Side with ice maker and water in door
Plz provide me with the full name and model of your appliance for there is a lot of diferent makes and sizes,plz reply asap so we can sort this problem out for you.
Thanks...
Wouter.
SOURCE: Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
