SOURCE: Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
SOURCE: LG Tromm WM2277HW will not spin both directions, LE error.
Short answer: The post+images by “chem-prof” on Jan 10, 2008 and the post with part instruction by “wolfster” on Dec 04, 2007 solved the problem!!! You guys are the best!!!
Long answer: We purchased the LG WM2277HW three and a half years ago. We have been VERY happy with the results. Last Thursday we got the LE error code after placing a single sofa cover in for a quick cycle. I’m not sure if this is what caused the part to go bad or it’s just the fact that this part might have a “time limit” so LG can make more money on service… (sounds like my Volvo!!!). Anyways, after freaking out for five very long minutes, I Googled the phrase “LG Tromm WM2277HW will not spin” and got directly to this page (WAHOO, FixYa.com!!! You guys are great too!!!). Read the instructions posted by “chem-prof” and “wolfster”. Following “wolfster” I went to download the user manual and exploded diagram from http://136.166.4.200/contents/Laundry/WM2277.htm, then I went to http://www.mcminone.com/ and typed “P/N 6501KW2002A” in the search. Got the “sensor assembly” part for $17.50 + $22.50 (2nd day air UPS). Make sure to note “Please send me a UPS tracking info” in the comments field. Got the UPS tracing e-mail from mcminone.com and waited…. Tuesday was my delivery day (Ohio to Florida). On 5pm got the part by UPS. At 5:15pm it was all assembled and first cycle was started to run!!! Now it’s my 3rd cycle and the baby LG WM2277HW is spinning like usual!!!
OK, now let me tell you, the images by chem-prof are great, but I found that if you take the three screws that attach the electric cords to the drambase it will actually make your life easier and it you will not need to disconnect one of the cords/plug, only the small one that attaches to the “sensor assembly”. See my image for the process:
A. Take off the 4 screws for the metal covering
B. Take center large screw (#2 on my list, it was a mistake…), this will not be as easy unless you have someone else to hold the dram from the front… but it’s doable after all, I did it!
C. Take off the magnets covering, this may require some shifting left and right, while pulling to the back (placing it back is not that easy, indeed watch your fingers when placing it back!)
D. Disconnect the cords attachment screws (#1 on my list)
E. Take the 6 screws of the motor (looks like a circle with orange cords around it!) (#3) and place the motor on a towel on the floor
F. Take off the plastic part (“sensor assembly”) from the motor
G. Place the new plastic part (“sensor assembly”) on the motor
-- Redo steps E to A backwards… voualla! You’re done!
H. Take your wife and the kids to a fancy restaurant for all the $$$ you saved!
SOURCE: vibration during spin cycle
Unless your front loader is set firmly on concrete
and leveled to perfection, the force of a heavy wash load spinning in
excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the
shocks that are used to dampen the spin cycle might have been broken or
damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
SOURCE: Why won't the drum spin on my LG Tromm front load washer?
I had the same problem and it was a bad sensor assembly (#6501KW2002A). You can order
it from an online electronics store (www.mcminone.com). Cost is approx. $20.
I fixed it based on a thread from 2007:
See http://www.fixya.com/support/t159708-lg_washer_wm1832c
But, here's what I did:
1. Unplug the machine.
2. Take off the back plate that has 4 small screws.
3. Unscrew the big bolt in the middle.
4. Take off the hubcap looking part the bolt was securing.
5. Unclip the two sets of wires on the bottom of the circle you are looking at
(the set of wires to the right are connected to the sensor assembly you want to replace).
6. Unscrew the 6 smaller bolts to take off the circular piece that the sensor assembly is snapped to.
7. Mark with a pen where the sensor attaches so you know where to snap the new one.
8. Unclip the old sensor assembly and clip on the new one
9. Reassemble.
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
