Building Materials Logo
T
Tom Beecher Posted on Oct 28, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Clicker universal Garage door opener remote control Model KLIK1U. How can I increase the range to open the door? Currently, I have to be within 10-15 feet of the door opener to operate. I have replaced the battery. No change. I purchased a new Clicker remote but no change. The opener is a Chamberlain Liftmaster Professional (1/3 horsepower) purchased from and installed by Home Depot.
Level 3:
  • Master 19,187 Answers
  • Posted on Oct 28, 2013
Master
Level 3:
Answers
19187
Questions
0
Helped
4338357
Points
82259
Check the antenna on the motor. It is usually a single thin wire. There also could be something nearby that is causing interference to the unit and it wont pick up the signal till the transmitter is close enough to overpower the interference.
4 Related Answers
SeanAA
  • Posted on Jul 25, 2008
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Anonymous
  • 3197 Answers
  • Posted on Jul 22, 2009
SOURCE: Universal garage door remote
I have a feeling your neighbor operated their door opener when you were programming your new clicker. Try erasing the memory of your opener and then program the clicker again making sure your neighbors do not operate theirs at the same time. To erase the memory hold the smart/learn button in for 10 seconds.
Anonymous
  • 10865 Answers
  • Posted on Feb 09, 2011
SOURCE: We have the chamberlain universal clicker klik1u
Hello iris.... Your remote control needs a new battery. Once you install the battery check to see if it works. If not, then reprogram the remote by pushing the programming button on the back of the garage door motor, then while it is flashing push the button on the remote to reprogram it. Joe
Anonymous
  • 113 Answers
  • Posted on Feb 26, 2011
SOURCE: have a 2006 Liftmaster professional 1/2 h.p garage
The opener should have an antenna wire hanging out of it. Did someone/something hang on it?
How do I get distance from opener will only open whenupclose?
Has it always been that way, or just recently.
Most garage doors will open for about 100 or 200 feet away.
If it just started, you can replace the remote battery.
Hope this helps.
Unable to program universal opener with genie pro max garage
Actually, this remote can be used with Genie Garages. See the article here on eHow - I used this to program a KLIK1U to work with my Genie Promax 2 garage. Hope that helps!
4helpful
I progammed by accident my #1 button on my KLIK1U to my #2 garage door. Then I seen the mistake, so I programmed my #1 button to my #1 garage door. Now my #1 button controls both garage doors and I now...
You're going to have to clear the memory on the openers. This is usually done by holding the learn button for about 15 seconds or until the led turns off. I'm not sure exactly what opener you have, so this may not be the case, if not, let me know exactly which opener you're programming your remote to.
1helpful
I have a WAYNE DALTON garage opener lost clicker and bought universal clicker model klik1u..Can not get it to program.
Go to this website for complete directions plus a video.
http://www.chamberlain-diy.com/doityourself/pages/productmodeldetail.aspx?modelId=1477
We bought 2 remotes both KLIK1U and successfully programed one. It works excellent. The second only works while either inside the garage or a few feet from the garage door (and that sometimes doesn't...
If one works OK, and the other has poor range, then it is either a battery problem (try swapping batteries with the good one) or it is faulty and needs to be returned to where you purchased it.
5helpful
2answers
I cannot get my universal Clicker by Chamberlain KLIK1U to work with my Quantum 3212 garage door opener even though it says that it works with this model. I have followed the instructions and tried...
The klik1u does not operate at a 303mhz frequency therefore it will NOT program to the quantum 3212 but the actual remote from Wayne Dalton is only 2 dollars more than wal mart charged me for the klik1u when I bought it to try
Top Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Building Material Expert? Answer questions, earn points and help others
