I ave toshiba c660. its buiit-in web cam is not working properly. when i use camera a blue light turns on and after closing it the blue light is still on. when i open the webcam again for the second time its not showing me the image .
Restart the computer and see if the blue light comes back on by itself. If you are still having problems visit the Toshiba support site for your country (or region). Download the webcam application compatible with your version of Windows (32 bits, 64 bits) and reinstall the application. Test it using the Start>Toshiba>Utilities>Webcam Application, or the Face recognition software. You close the running application by clicking the x at the top right corner of the application window
SOURCE: Web cam problem
ya vista have some problems go to your internet option and download manually the latest update of your webcam .this may be a problem because u are using latest version of yahoo but your web cam do not support it or either add xp also in ur laptop.
SOURCE: Hey, well, I got a laptop, and my built-in camera is not working
Hi Chris - don't rate this until we fix this. Try this:
Go into control panel, programs and features if using Vista. click on camera assistant software. Click on change at the top
and then choose the repair option . Let me know what happens. Thanks.
Jeff
SOURCE: The web-cam is not working. I only get "web-cam
Re-install the driver for the webcam.
Follow these steps to re-install the driver for the webcam. You will
need to be logged in as an Administrator or have an Administrator
password ready.
1. Click the Windows Start
button.
2. Click Control Panel, System
and Maintenance and then Device Manager.
3. Right-click on Chicony USB
2.0 Camera and select Update Driver Software.
A yellow exclamation point indicates that the camera is recognized by
Windows but is not working properly, probably because of problem with
the device driver
4. Select Browse my computer
for the driver software.
5. Select Let me pick from a
list of device drivers on my computer.
6. Select USB Video Device
from the list, and click Next.
7. If the message “Windows
encountered a problem installing the driver software for your device”
appears, click Close.
8. Restart Windows.
The webcam should now work properly.
Thanks
Testimonial: "Thanks for the advice. I didn't use it exactly, but went to Device Manager, took a deep breath, and deleted the web-cam driver and restarted the lap top, allowing the machine to reload the web-cam driver, and surprise, the web-cam now works perfectly. Thank you very much for your kind advice. Cheers Dev D "
