Question about LG HBM 730 Bluetooth Headset Wireless Headset
LG HBM 730 wont take pair code "0000"
I have tried numerous times to put code in & it just wont take the code, it says "passcode mismatched".
I have tried typing in at differnt speeds slow , fast 7 just wont take it.
Any sugestions??? Please help me!!!
  • Anonymous May 02, 2009
    How do i uninstall paired devices to install the HDM730
I was having problems connecting with my HBM-730 so I got fed up and deleted it from the list of paired devices and set it back up again using passkey 0000. It works fine now.
Hope that helps.
Posted on Apr 27, 2009
I have tried 0000 and 1234 as passcode but I still get 'Passcode mismatched'. Help please
oh..............!! you can try 1111 on your pc first......then the cnnect your mobile to the pc and when they ask for the pass code in your mobile type the same (that is 1111)........this is my suggestion...you keep trying it.....thats what i did......if you are lucky you problem is solved.
Mar 21, 2014 | LG Ku990i Viewty
When i enter the passcode it tell me passcode mismatch
Have you put your heaset in paring mode prior to trying to pair it with your phone (or computer, or any other bluetooth enabled device)? If not, start with it turned off. Then, press and hold the MFB (Multi-Function Button) for some 8 seconds, until the indicator light is steadily lit. It is in pairing mode now. Make your phone's bluetooth application search for new devices. After a while, the WEP200 should appear on-screen. Make it connect. If a paring code (or PIN, or passkey) is required, enter '0000' (four zeros).
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Feb 15, 2010 | Samsung WEP200 Wireless Headset
I put in the passcode 0000 and it still say the passcode is mismatched. wat should mi do now....
i'm assuming your device is picking up the headset just not accepting the code.
has the device ever been linked to another before? Motorola headsets are/were known for only being able to sync to one item.
Dec 17, 2009 | Motorola Mobility H700 Wireless Headset
Need key code for kenwood receiver kdc-mp228
There are a few types of override procedures for Kenwood.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
"TRACK UP BUTTON" for 3 seconds.. and youre done.
Aug 22, 2009 | Kenwood KDC-MP228 CD Player
0000 passcode mismatch
the traditional 0000 passcode did not work with my new SA505, being frustrated I decided to just start at one and put four 1111 in, and low and behold it worked. I now can pair it and it works great, Just a lucky guess but hey it worked.
Jun 11, 2009 | Radio Communications
My phone is locked up and wont let me type the password in.
you locked the sim card by entering your passcode wrong more than 5 times.
call your provider and ask them for a PUK code and they will give you one.
also you can walk in to a provider store for help and log onto the provider website for a puk code.
May 31, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Need the pairing passcode for Bluetooth
It doesn't matter what the code is, as long as you enter the same number at both ends
if it help rate the Solution Please
21/Apr/09
Apr 17, 2009 | GPS
Keyboard locked and i'm on my last try? 8350i curve with nextel
Remember that if you type in the PIN "5815" (example) on the BB keyboard without holding down the ALT key you are really typing "dxwd" but you can't see it because it does not show the typed letters only the *****. Try entering the letter form of the numeric passcode. One more example. If your passcode was "1234" enter "wers".
Jan 20, 2009 | RIM BlackBerry Curve 8310 Smartphone
Radio lock
Try this if it works to your unit;
Type 1
Type 2
Type 3
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Sep 07, 2008 | 2001 Chrysler Sebring
Password reset?
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
Type 2
Type 3
Nov 04, 2007 | Kenwood KVT-617DVD Car DVD Player
LG HBM 730 Bluetooth Headset Wireless Headset Logo
853 people viewed this question
Top LG Radio Communications Experts
B.Th. Pluijm
B.Th. Pluijm
Anthony Ward
Anthony Ward
Brandon Hunter
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
