Question about Swisher 44-Inch 12.5 HP Trailcutter #RTB12544
Change belt how do you change the belt.I cant find any thing helpful in the manual.Can any one help,do you have to pull the engine off.We have a 44 inch rough cut 14.5 hp
    New Friend:
Changing the belt on the swisher 44' rough cut - mine is a model RTB134412v. You have to remove the belt guard (4 bolts) and then the 6 bolts holding the engine on to the deck. Lift (or tilt) the engine up and loop the 1/2"x50" belt (I got a husky replacement belt at tractor supply) through the wire belt guides and around the engine belt drive. Then loop the belt around the larger blade drive. It takes about 30 mins or so. Hope that helps.
Posted on Jul 01, 2014
2 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 138 Answers
SOURCE: My Swisher Rough Cut 12.5 HP 44 Inch mower - The
I dont believe there is a shear pin on your blade spindles, what I have found on these machines is the the spindle nuts on the balde spindles sometimes loosen or wear and no longer squeeze the pulley on the blade spindle. To make this process easy on your self you need to tighten these with a impact wrench. However if you dont have access to a impact wrench you can use hand tools and block the blades you are trying to tighten with a wooden block. Just make sure you block the blade you are trying to tighten
Posted on Aug 30, 2009
Would like a manual on how to change a belt on a swisher 44 mower model no RK 10544
Swisher RK 10544 pull behind mower breaking belts - Fixya
www.fixya.com/support/t14407937-swisher_rk_10544_pull_behind_mower
Sep 21, 2012 - Also - is the belt snapping clean, or do you see a burnt, worn spot? Posted on May 28, 2010. Helpful 1; Not Helpful; Flag. Testimonial: "Thank ...
how to change the belt tension on Swisher FC10544BS 10.5 HP 44 ...
? 2:45
https://www.youtube.com/watch?v=zP3KPc32m5U
Jun 8, 2017 - Uploaded by Adventures In Living
link to mower: http://amzn.to/2sGS9uF how to change the belt tension on Swisher 10.5 HP FC10544BS 44 ...Missing: rk
how to change the air filter in the Swisher FC10544BS 10.5 HP 44 ...
? 2:26
https://www.youtube.com/watch?v=ykOhC5qyO74
link to mower: http://amzn.to/2r5MwcA how to change the air filter in the Swisher FC10544BS 10.5 HP 44 ...Missing: rk
How to Replace a Drive Belt on a Swisher Mower ' Hunker
https://www.hunker.com > Home Hacks & Answers > Garden & Lawn > Lawn Mowers May 18, 2011 - The drive belt on a Swisher mower, such as the Swisher trail mower, powers the blades located under the mower deck. The trail mower is a ...Missing: rk ‎10544
May 21, 2018 | Swisher Garden
I ve just changed water pump,the battery was weak friend pull the car to kickstart while trying to kickstart timing belt brakes while car is in motion but not idling,what went wrong in the engine?
depends on car engine, make and model. if it is a non interterence engine probably nothing wrong. If it is an interference engine damaged velves and pistons. Could be expensive fo fix and you HAVE to remove head or heads to check now . If you are going to do mechanical work in future always work with the help of a workshop manual...most non single marque mechanics use manuals too for things they are not familiar with
GOOD LUCK
Jul 02, 2015 | Cars & Trucks
Need size and # for belts
ogst2803e.pdf (application/pdf Object)
hello c, here is the manual, auger belt 1/2 x 44 long,,drive belt 3/8 x 35.5 long,you can look at the parts brake down for numbers,just download and print manual,hope this helps,,
Feb 20, 2012 | Garden
What size belt for my swisher 44" pull behind
I just replaced the belt on my 44" Trailmower and since I had to get it up and running without waiting for new Swisher 4220 belt I found an ordinary V-belt 1/2"X72" whith overall with of 74" works OK
Jun 28, 2011 | Swisher 44 Iinch 11.5 Hp Trailmower...
I've lost the manual and I can't remember how to change the sand paper belt. There is a lever on the side which I've sort of tried but don't want to pull it too much incase its the wrong thing...
Pull that lever all the way out, you should see the front wheel pull back and the tension on the belt should release so you can pull the old belt off and put the new one on. Center the new belt on each wheel then push the lever back down. When you first turn the sander on check that the belt is tracking in the center of the wheels. Turn the tracking knob to adjust if necessary.
Sep 08, 2010 | Tools & Hardware - Others
Changing alternator on 1996 impala and cant get belt back on please help car is stuck in garage that is not my house   please help
need belt routing sequence or what im not sure how to help , if you have the belt on the right way there should be a diag on the waterpump shroud , other than that if that is gone ck local auto parts store you have to take a 3/8s drive ratchet to pull back the tensioner to load the belt i usually load the belt on all pulleys except the idler pully then i preload the tensioner and slide the belt under that pulley last , im thnking you have a 3.1 or 3.4 litre engine
Dec 19, 2008 | 2008 Chevrolet Impala
Toyota hilux ln-130 engine dianostic codes
How is it they cannot tell u wutthe probem is? That's odd. Ur telling me no diagnosticprocedure was done to the vehicle? I have a manual for a toyota vehcil with some codes. I think the same 44 would govern most toyota veicles. When I I get hom I'm gonna check and c wut it is and get bak to u
Oct 11, 2008 | 1991 Toyota 4Runner
Swisher 44-Inch 12.5 HP Trailcutter #RTB12544 Logo
526 people viewed this question
Top Swisher Garden Experts
dannydoesita
ray gallant
George Merkley
George Merkley
Are you a Swisher Garden Expert? Answer questions, earn points and help others
