SOURCE: Where might I buy a new joystick controller for my
You need to contact hoveround. Only Hoveround dealers can work on hoverounds and get their parts.
SOURCE: I lost the Hoveround MPV5 manuals
Hello. Call the company directly to get what you need
1-800-542-7236
SOURCE: LOOKING FOR CONTROLLER FOR HOVEROUND MPV5
Those are only available through Hoveround and retail for around $1159.00. You may want to have a Hoveround Tech come out to diagnose the power chair for $50 to make sure that is what you need before spending that kid of money.
SOURCE: How can I get a manual for the Hoverround MPV5?
If the power chair was stored for a while, the batteries may have gone bad. There is a gel inside them that needs to be put on a current regularly or it will solidify. When you connect the charger, you get a green light because it senses the batteries are full; unfortunately they are full of crud, not power. Try replacing the batteries to see if that solves the issue. You can probably take them to an auto parts store or Interstate Batteries to have them volt tested. The type of battery you need is a U1, 12volt, 33amp and you will need 2 of them.
SOURCE: Online owners manual for Hoveround MPV5
The full manual is not available online. It must be purchased directly from Hoveround for $20 plus shipping. Please call 800-964-6837, you will need the serial number from your power chair, located inside the manual brake release above the footrest.
