Check the gap on your plug. .030 is what it should be. also make sure that your
kill cable is working properly and not grounding the engine out.
the gap for you magneto should be set to .010 to .012
loosen up the magneto insert a standard business card or 3x5 card
then turn the flywheel so that the magnet on the flywheel pulls the magneto into it. then tight the magneto mounting screws down. try spark now. always use fresh gas. -no-water- if in doubt throw it out.
gas is BAD after only 30 days.
