Cord snapped. Any way I can fix this myself? Should I try to open the housing?
Good job on the cord replacement. Most people take the cover off the spring and then find out it is nearly impossible to get the spring tension set. I have personally repaired dozens of these cords that have been messed up by owners that did that.
If anyone has this problem, just do what this post says...remove the assembly and turn the pulley until you can get to the part of the cord that is broken...grab the end that is broken after you get it out of the opening with a vise grip and pull the cord out fully and lock the recoil spring with a vise or vise grip (but don't crush it)...then replace the cord and hold the end of the cord pull fully extended and remove the lock and allow the spring to recoil...and reinstall the assembly.
Simple, but THINK before you take the housing apart. It is REALLY TOUGH to reset spring tension properly.
Ok I fixed it myself. Opened housing, re-threaded the cord through hole and tied its end to a screwdriver. Reattached housing and voila!
