SOURCE: Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
SOURCE: Maytag Gas range
Had the same problem.... just replaced the ignitor in the bottom of the oven... worked like a charm. 10 minute fix
SOURCE: maytag gemini self cleaning oven feature
Close door on lower oven (upper oven is not self clean). Press "Clean" pad. Press More pad or Less Pad. H is 4 hour clean, M is a 3 hour clean cycle and L is a 2 hour clean cycle. The door will lock and cleaning will begin. Good Luck!
SOURCE: Can't Unlock oven doors after "self-Clean" maytag double oven
I was advised to disconnect power for at least 60 seconds to clear the control board. I did this several times with no luck getting the door unlocked. However, a few hours later, the door did finally unlock. Not sure what ultimately caused the door to unlock, but happy that I did not have to replace the control board.
SOURCE: Maytag Oven MER5770AAA gives F9 code and won't
To reset door latch, press "cancel" to clear F9 code. Depress and hold oven door light switch (plunger style on door frame). Latch should reset.
Before you go working too hard to get
you oven to go into the self clean mode(self destruct)....check out
this tip...
Self
Cleaning Oven Problem
heatman101
Wish I had read this first. I never would have used the self cleaning
option. Thanks for the info!!
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
