Question about JVC HD-52Z575 52" Rear Projection HDTV-Ready Television
Just replaced the lamp about a month ago tv was working fine again but now i turn it on and it's fine for 10 to 20 mins then it just turns off and the lamp light blue blinks and the red light blinks to at the same time. i push the power button and they stop blinking then i hit power again and the tv works again for about 10 mins sometimes a few mins more or a few mins less
    New Friend:
You might want to check and see if that was the right lamp for that tv. You might have the wrong lamp
Posted on Nov 18, 2013
6ya staff
SOURCE:
freetek
Steve Allison
  • 5569 Answers
SOURCE: Lamp light blinking, Power Light blinking, TV off
Your description of the problem points to a power supply in the process of failing.
If it was mine, I would leave the set unplugged overnight, remove the back panel of the set, locate the power supply (likely on a separate board related to the incoming AC cable and will have larger components on it), look for an assembly number (often on a printed label), contact the manufacturer's service company and inquire about replacement or repair cost.
When you plug it back in, note whether it behaves normally at first turn-on. If is does, this tends to support the suspicion of a failing power supply since some of the passive components in it have had a chance to recover before weakening again.
Modern supplies are a good bit more efficient than 'linear' supplies of yore but are far more complex and much more dependent on quality of components.
Posted on Jul 28, 2009
Robert Johnson
  • 395 Answers
SOURCE: JVC TV lamp indicator light blinking new lamp
if you purcased a LTI lamp then the possibilty of a bad lamp may be the case. LTI lamps are cheap and are poorly manufactured. if it is a JVC lamp then you may have further problems such as lamp balast, or thermal sensor. clean the fans and filtersfor better air flow. keeping the lanp cool is important for the life of the lamp.
Posted on Apr 19, 2008
Anonymous
SOURCE: Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Posted on May 11, 2008
Anonymous
SOURCE: jvc tv
when both the blue light and red light are blinking it means 1 of 3 things. 1. lamp replacement. This often works everytime for the repair. TIP!!! DO NOT USE ANY OTHER LAMPS OTHER THAN JVC AUTHENTIC LAMPS. ANY OTHERS AND YOU RISK DAMAGING YOUR TV FURTHER. 2. the fans are not working properly or need to be replaced. They need to be cleaned every so often and they will stop working from burn-out if not done so. This repair will cost you less than 100 dollars. 3. The ballasts are defective and need to be replaced. The ballasts themselves run about 150 dollars. I tell you I have fixed this TV more times than I care to count, not to mention the number of lamps I have gone through. The guy at the TV repair place now knows me by name when i come to buy lamps. :(
Posted on Dec 07, 2008
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: I have a JVC HD52z575 that when I turn it on the
Power supply would be the issue the fix would be my good friends @ www.teexp.com I hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 13, 2009
Code 34 replaced lamp with 2 new osram lamps may run for 5 min or 5 hrs shuts down solid red light code 34
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
Sep 25, 2014 | Mitsubishi WD-60737 60 in. HDTV
I have toshiba 50hm67 replaced lamp...tv worked, then quit working again, and giving blinking yellow lamp error light when turn on...after a few moments tv tries to turn off and back on
OK. I have this same issue. I replaced my bulb a month or so ago. TV worked fine. Then one morning I turned it on and it was on for a good while, till it went to a black screen w/ sound only. Lights were going through the reboot process as designed for 8 attempts before it went to the solid red light. From the red light, if I unplug and plug back in, the tv will come on for a given amount of time, which varies, and then cut to the black screen. A repairman told me that it sounds like the digital board is bad. He wanted $150 for the board and $100 labor. I cannot find anywhere where the board would be located or where I can purchase a replacement.
Jun 15, 2011 | Toshiba 50HM67 50" HDTV
I have a 65 inch mitsu DLP, replaced the bulb 6 months ago.. Worked fine until this week.. Now the TV will power up, turn on, then show a picture for a second then go black.. It repeats this nonstop.. ...
Sounds like the Lamp is over temperature. Either the fan went out or the filter is clogged! You might check the filter first. I hope this will help you...
Jan 07, 2011 | Mitsubishi Televison & Video
The power light is red and the bulb light is blinking red
OK...Did you replace the lamp with a Sony original? If you did, then carefully check that the door is closed properly.
May 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
TV turns off
Your Ballast Board could be problem Now, pull back off watch as Lamp trys to turn on if there is a Spark coming from Ballast Board Lamp is Defective, If No Spark problem is in Ballast Board.
Sep 21, 2009 | Samsung HCM5525W 55" Rear Projection...
52HM95 Lamp Issue
The Tv will shut off and sho error if the ballast is bad. Replace the ballast and you should be fine.
Mar 22, 2009 | Toshiba 52HM95 52" HDTV Projection...
JVC HD-ILA (HD-55G456) Lamp has to be re-positioned everytime TV starts up
Not the same problem, but I have the lamp light and power light blinking simultaneously and haven't figured out that one yet
Mar 28, 2008 | Televison & Video
Problems with Mitsubishi WD-52525
When you replace these laps on these TV's they have an internal clock to countdown the lamp usage. After installing the new lamp the TV asked you if you replaced the lamp and you should answer yes. If not its going to ask again. First thing is go through the motion of replacing the lamp take the lamp out etc. then place it back in the set and turn it back on. Follow the on screen instructions and that should reset the lamp timer.
Jan 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
167 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
