KitchenAid KSB5 Professional Stainless Steel Work Top Blender Logo
A
Anonymous Posted on Oct 20, 2013
Replace the gasket on a ks560evo blender - KitchenAid KSB5 Professional Stainless Steel Work Top Blender
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
My blender is leaking is it possible I need to replace the gasket. If so where you get a new one.
It is probably a worn out gasket. The cheapest and best results i have gotten have been going to the manufacturer website and most of them give you the ability to buy replacement parts.
Kitchenaid blender model # KSB565OB0 is leaking from the bottom. I have taken it apart to try and find the problem. The gasket is fine and the pitcher attaches and locks but it still leaks everytime we...
Check for cracks in the bottom of the glass.If it continues leaking then the gasket is compressed and no matter if it visually looks good, cause it has lost their sealant skills. Replace the gasket
2helpful
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
1helpful
Blender seems to run right until you put glass jar on.runs very slow.
Disassemble the base from the jar, and check the placement of the gasket. Reassembly, with the jar upside down is gasket, blades, then base. While disassembled, rotate the blades by hand just to make sure that they aren't in a bind. Replace if defective.
--W/D--
1helpful
I want gasket for cusinart blender (600watt.)
mcdevito75 here, You should be able to contact Cuisinart omline at Cuisinart.com to reder new gasket.
1helpful
Leaking cuisinart smart power 7-speed electronic blender
There is probably a hairline fracture or tiny crack in the blade assembly itself - replace the blade assembly - it will automatically come with a gasket, so you will have an extra.
Top KitchenAid Blenders Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
