Question about Hamilton Beach Water Cooler with Storage Cabinet
Ever blue water cooler making nise and heats up entire bottle when both hot and cold switches are turned on.
5 Suggested Answers
mgprice
Mike Price
  • 744 Answers
SOURCE: My hot water on model #87330 cooler has stopped
Unfortunatly this is going to be a bad heating element or high limit thermostat, It's going to be cheaper to buy a new one or just make do with cold water. Sorry I can't be more helpfull but i worked on these things for a while and the company i worked for would rather buy new then put time effort and parts into a $100 water dispencer.
if I can be of any more assitance please feel free to comment again.
Posted on Jun 23, 2009
sherrianne75
SOURCE: How to clean/repair water cooler
I have a hamilton beach water cooler with storage cabinet # 87330. The cold water is not cold and the cooling light stays on. What is the problem and how can I fix it? Thanks!
Posted on Dec 20, 2009
VMD011
  • 10 Answers
SOURCE: My water cooler won't cool
Is this model 87307? I am looking to buy this dispenser 87307. Pls e-mail me at vmd011@hotmail.com Thanks
Posted on Nov 16, 2010
VMD011
  • 10 Answers
SOURCE: Hi I have a Model 87307 Hamilton Beach/Proctor
I want to buy this dispenser. Please e-mail me at vmd011@hotmail.com
Danny Taylor
  • 61 Answers
SOURCE: I have a HB Water cooler Model 2312C, Type WD01,
Problem: Water is not hot
Possible Causes: Dispenser is unplugged
Solution: Push plug completely into outlet
Possible Causes: Heating switch not on
Solution: Check to be sure heating switch is turned to ON
Possible Causes: The fuse is blown/circuit
Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker.
2. If too many items are plugged into a single circuit, move some items to a different circuit
Possible Causes: Temperature limiter tripped
Solution: 1. Set the hot and cold power switches to OFF
position.
2. Wait five minutes, then set switches to ON position.
3. Wait 30 minutes for water to heat or cool
Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
Posted on Jan 17, 2011
I own a watercooler 4 yrs old model # whkmd30The bottle water get extremely hot. There is good ventilation Any suggestions
Your water cooler has a Hot water section, also-- correct?-- You have 2 faucets, right?-- One COLD and ONE hot!
Is it possible that the section that does the HEATING, is stuck ON and is in some way heating the water back up thru the connection, into the big bottle?
Another possible thought: Is there a heater to prevent freezing of the bottle?-- Maybe it is stuck ON
Note: Your question ended up under Vacuums-- We are just trying to help-- Feel free to re-list your problem up there where water coolers are-- OK?
Sorry we couldn't be more helpful here in the Vacuum cleaner area-- :-)
Mack B
Jan 29, 2011 | Vacuums
position.
Feb 18, 2010 | Hamilton Beach Water Cooler with Storage...
Not dispensing cold water
turn the system of unplug and turn the machine upside down without the water bottle. There shud be 2 drain plugs underneath. remove one at a time and force water or air backwards thru these drains to ensure no obstacle in pipes. Also check inside that no pipes are bent closed so as to block water from flowing thru. It doesnt work via a pump but a simple gravity feed system. also the cooling works diferent to a normal fridge, doesnt have gas in it it cools by a heating element that cools on the one side and heats on the other side. Also check that ur fan on the cooling side is still running properly it shud turn of after a couple minutes and turn on when the water gets hot again.hope it helps.regards.viv
Dec 30, 2009 | Hamilton Beach Water Cooler with Storage...
My hot water on model #87330 cooler has stopped working the switch is turned on in the back
Jun 23, 2009 | Hamilton Beach Water Cooler with Storage...
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Model YLR2-5-90HZ3 cold/hot/water dispnser with fridge won't heat
I have the YLR2-5-96H2 and hot water stopped heating up. I unscrewed the casing and unplugged the connections to the circular heating element and 2 circular probes. Brushed off the white dust build up on the probes and it started to heat water again. I ruled out faulty heating element, because it got really hot just seconds after turning on the hot water switch.
Dec 18, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Cold Water not squirting out cold water
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
Nov 07, 2008 | Hamilton Beach Water Cooler with Storage...
Water is hot on both cold and hot side of my water cooler. water bottle on cooler is extreamly hot.
are you talking about a water cooler dispenser with hot and cold valve?
if you do, the cooling side is not functioning well.
is the compressor running? if not, check the thermostat.
if the compressor tries to start but can not. check the relay of the compressor, it may be bad.
if the relay is ok then the compressor is bad.
another thing to look at is the hot water thermostat. it may no longer functioning as to the cause of the bottle to be extremely hot.
tnx 4 using fixya,
drcool
Oct 06, 2008 | Whirlpool Refrigerators
Advise
you need to purge the air out of the "hot" side after placing the bottle on top. If not enough water is inside the chamber the water will boil.
Jul 07, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach Water Cooler with Storage Cabinet Logo
151 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
