Ryobi Model 65020 gas tiller dies when engaging the throttle
Cultivator starts fine, idles fine but when you engage the handle to increase the speed it basically dies or what we use to call "bogs Out" or starts getting slower until it quits. Spark plug looks fine.
Same here but I think it must have had bad gas. I can get it to run fine on choke then when I engae it dies. Have you found the fix yet? Same here but I think it must have had bad gas. I can get it to run fine on choke then when I engae it dies. Have you found the fix yet?
You can't post conmments that contain an email address.
I believe that unit utilizes a centrifical clutch. try decreasing the idle speed and see if the tines stop. They should then engage as throttle is increased.
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
if the idle is too high the tines wont stop due to the tiller tines are run by a "centrifuigual clutch" which means when you increase the throttle speed the tines will start to turn : there are 2 adjustments you can try,1) adjust the idle screw under the carburetor where the throttle adjustment and a triangle piece of metal touch(your throttle cable wire will be attached to this triangle) ,if the triangle and idle adjustment don't touch and there's a gap between these 2 pieces close the gap by adjusting the 10mm adjusting nut,this will correctly set the idle #2) adjust the idle adjustment screw talked about above till the tines dont turn with throttle set at idle or lowest speed setting
Ok I have r Royobi Tiller (30CC Gas) And last year it ran fine after rebuilding the Carb. This year it was "hard starts" Idles fine, (Tiny whisps of blue smoke in exhaust with correct ratio) Even seems to run better with the choke "on" but still...at idle only. as soon as I touch the throttle...its bogs down in tune with how much gas I give it. Little throttle? Little bog down, Little more throttle? Almost stalls, a normal throttle rev? it stalls dead! Then starts right back up again in 1 pull and idles fine again!? WTF? So after cleaning a clean carb again, (twice) and seeing no change I thought I'd go look at the original diaphragm and compare it with the rebuild kit diaphragm (which is the one in the carb.) And guess what? The replacement has a larger rivet by a factor of "2". So basically it was flooding the carb, I bent the needle tang down, better but no cigar. But I could rev it half way now. A second disassemble to bend it yet a bit further and Vrooom vroom vrooom ****! So check your needle valve even though you think its 100%. (Especially if you rebuilt the carb with a kit!)
Try better quality gas. I had the same problem.
Ethanol too high in lower grade gas. Buy better grade or ethanol free.
Mine works fine with better gas.
