There is no grease but oil used in this tool There is a special consumables kit for to order But BEFORE you made a self service for this machine there could be a rip somewhere in the spindle control first by ringing listen to the sound tap on it it with a piece of metal that the spindle sounds well without also all in and outside parts naturally and off if it does is the sds chisel drill conduction inside the spindle is not round toppen instead of square topped because of faultering on the chisel or drill in short time to expect. in that case if the spindle is bad its better to remplacement the whole tool by Bosch for the working hours on all parts are reached, but if the spindle is smooth order 1 615 437 511 oil reservoir and 1 617 000 A16 thats the right maintenance partsset for this machine and its is easy to service by yourself a little 2 or 3 hours without special tools for special kevlar rings like some other brands often have. but a bank vice and some little screwdrivers noseplier, shaft retaining ring pliers a solvent cleaner for the old lubrication to remove.
AND IMPORTANT dont forget part 104 best to give that o-ring some grease that it will not move out by insert the spindle (sometimes)
one thing is very important there must inside be 2 adjust rings between the gears 47 and 51 if there is only one shimring = used then order some shim rings ( there must be made an adjust between 0,08 and 0,22 mm between the gears tooth but only when there is only 1 ring was used that can be happen in a rare case. the drawing is to find also by bosch in america the partnumbers are the same.
http://www.powertools-aftersalesservice.com/public/boschprof/service?p_auth=ZdEJ7pFj&p_p_auth=R78yYhDo&p_p_id=WSRP_bc93764e__6873__4b00__9a29__b331c9759da9&p_p_lifecycle=1&p_p_state=normal&p_p_mode=view&_WSRP_bc93764e__6873__4b00__9a29__b331c9759da9_wsrp-navigationalState=L0JPUy9QVEFTLVBULVNJUy1TaXRlL25sX05MLy0vRVVSL1ZpZXdQcm9kdWN0LURpc3BhdGNoO3BnaWQ9YmI5NWI3MGRjM2E3NzQxY2ExYzA0OGYyM2IzMDdhNWQ4RkJCO3NpZD1Zdks0RVZOU3dzVm1OZ3M3YnNlazZselpkRGtMODVwSi1QTTd1dEh5ZERrTDg1cEotUE09
SOURCE: looking to add oil to rotary hammer Bosch / Bulldog
the oil seal is broken, remove front cover at the chuck end of the drill, and replace the seal,
SOURCE: need \rnBosch Rotary Hammer Manual 11255VSR
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000001/r01003v-1.pdf
here you go!
SOURCE: looking for an owners manual for a 5/8 bosch
If you go to Boschtools.com you will find the manual you are looking for. They are all on the web site.
