Make sure there is a video cable of some type running from the back of the Philips to the television, and make sure the TV is on the correct source channel. Make sure the home theater system is in disc mode.
I will list some codes. The manual for this remote does not list a theater system at all. That does not mean one of these code will not work. It may be a bit more challenging to figure out which "heading" the code exists.
Four codes are listed for a Phillips DVR/VCR Combo from the manual for this remote.
145
067
101
034
DVR Receiver code
001
There are some codes marked under "Audio" as well.
Please keep in mind that it is completely possible that the remote you have may not be compatible for that home theater system.
Should this be the case you can get a universal remote that is very inexpensive (often times less than $10) that will seek and find codes removing the seeking number code trouble.
These remotes you aim at the device you want to use and it finds the code for you, hassle free.
Read the universal remote instructions. You should be able to enter setup and hit the off button, maybe hundreds of times until the tv turns off. When you turn it back on, you're set....
I have similar problem with a Philips CL034 Universal Remote and a Memorex MVD2047.
The Philips/Magnavox codes listed at this link did NOT resolve the problem. I tried all Memorex codes and tried the "all coded step-through" method.
http://www.universal-remote.net/philipsmagnavox.html
The above is NOT a solution, rather a note on a time consuming attempt to a solution.
