Have you checked to see if the outer throttle cable is properly seated at both ends?
Check the seating of the throttle cable outer sleeve, it sounds like the cable is being pulled tight. Try disconnecting the cable and working the throttle by hand at the carb. As you already know , to run at full throttle , the carb must be giving full air and fuel, that means the throttle body must be full open. If the cable is not the problem , check to make sure the springs are around the right way and they close the throttle when released. Hope that is helpful. Cheers
SOURCE: unable to start Ryobi 410r cultivator
After starting close the choke , push the lever back in
Vitally
SOURCE: ryobi 410r cultivator needs intital carb adjust
screw in lightly till seated then back out 1 turn each. low is for idling and turn in or out for best idle then run full throttle and do the same for it, get highest rpm then turn out 1/8 more on the high jet.
