Yardman pony no reverse forward jerking
SOURCE: My Toro Lawn Mower Model 20016 no longer moves
Your transmission is bad,need to have one ordered.
SOURCE: oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
SOURCE: John Deere LT155 Lawn Tractor has trouble going uphill
u can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
SOURCE: The rear wheels will not turn in reverse at all. I
Rear wheel drives like this have pinion gears with rachet pawls that allow them to go backwards freely while locking when the transmission drives them.
You need to take off your rear wheels and carefully remove the pawls. They look like little squareish metal shaft keys with springs under them. You should notice that the keys or pawls are covered in what looks like grease.....which is actually worm metal from the pinion gear and oil mixed together to form this pastey greasey substance. Clean all that stuff off and lightly oil *( light oil...3 in 1 kind of oil) and reassemble.
You should hear the nice clean clicking of the rachet pawls as you roll backwards again!
Good luck and be careful!
SOURCE: what type of oil do you use for 6.5 hp yardman
The manual will call for 30 weight, but 10w30 works just fine. Be careful to not overfill the crankcase. Your machine will take 16 - 18 oz's when the crankcase is empty.
Tim
