SOURCE: sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
SOURCE: Sony trinitron 29 inch kv j29mn
Possibly dry solder joints or faulty coupling capacitors around the audio section.
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
I have your service manual but I can't find any reference to 9 flashes, are you sure it is 9 with out a pause?
see below from manual.....
SOURCE: Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I
have over 10 years experience in electronic tech
support.
I
know this isn't what you want to hear, but the problem you've
described can't be fixed with troubleshooting.
Your TV
will have to be repaired. There is a part that has developed a defect
and needs to be replaced. If you're still in warranty, the TV will be
repaired at no charge to you. The warranty would likely be at least
one year from the date of purchase from the manufacturer. If you
purchased an extended service
plan
they will repair the TV at no charge as well.
If the TV is no
longer in warranty, it will likely cost a minimum of $150 parts and
labor. This is assuming that you only need one circuit
board
or small part. If the problem is more than one of the circuit boards,
the price of repair could go much higher.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
