The likely problem is the drain leading from freezer to bottom of refrigerator is clogged or stopped up. I will send you to another link so you can see and get pictures and answers to help you solve this.
http://appliancejunk.com/forums/index.php?topic=22.0
http://servicepartstec.blogspot.com/
Let me know if this help, Sea Breeze
Did you get a chance to look at the link I provided that shows almost the same situation that you have. He also resolved the problem by improvising and making a few changes along the way. I also will help you through this. Do you have a camera? We may need to replace the part that is where the styrofoam cup. I will see if there is a replacement part. You try to remove the pipe and clean like in the photos that are at the link below. I will be back with you. Sea Breeze
http://appliancejunk.com/forums/index.ph...
I can see now that is a part that is not listed as a replaceable part. My hopes are that someone you know can fabricate something better than a Styrofoam cup to catch the water as the freezer defrost and drains water down to the pan next to compressor.If you need anything let me know. Sorry I could not find a part for you.........Sea Breeze
Thank you. But, the drain "cup" in my fridge is a piece of styrofoam in a plastic housing and seems to lead nowhere. Also, there is no elbow/hose on back of the fridge. The drain hose drops from the inside directly into the drain pan. Where do I go from here?
