DRYER WILL NOT START.LIGHT WILL NOT COME ON. DOOR SWITCH READS GOOD.BREAKER ON. POWER TO DOOR SWITCH.
Same thing as other owners above...Dryer is five years old and is in need of a good cleaning of lint build-up. Model no. PYET444AZW.
I put a large load of clothes, which probably should have been spun again, into the dryer. When I returned the clothes were still basically wet, and the light in the dryer would not come on, and nor would the dryer start.
Tested the circuit breaker. OK. Tested the outlet with a tester pen. OK.
So in searching the internet for a solution, I found and read this string. Found the fuse, called my local appliance parts store and bought a thermal fuse kit for CDN$48 (incl sales tax). Kit came with three fuses.
Just opening the top of the dryer was a chore for a complete novice. However, the entire top is hinged at the back -- so at the front of the machine, just gently poked a slot screwdriver in the gap ringing the sides near the top, twist screwdriver and lift. Big fuse is easily accessible at the top near the back of the drum. It's a round thing about the size of a quarter screwed into a metal frame with two crimped-on wires coming out the top. One screw to removed the frame. Then detached the crimped-on wires, and removed the fuse from the frame with two more screws. You will need a smaller size ratchet or nut-driver.
While you have it apart you might as well change the second nickel-size fuse, too, although it is more of a pain.
You have to remove the coiled elements, which are basically just big springs. They come out with one screw on the right and a little finesse. The second fuse sits on the right-hand side of the metal box surrounding the coiled element. The screw for the coil also held the frame for the fuse in place, but the frame will still be secured to the box with a couple of small tongues. So you will still need to kind of lift and pull up on the frame housing the fuse. It requires some patience and finesse. Remove the crimped-on wires, and change the fuse.
Of the two smaller replacement fuses that came with the kit, there was one marked for a gas dryer and another for electric. (The big fuse was good for both.)
Then start putting it all back together. Took me two hours in all. But now that I have done it once, it would hopefully take me only 30 mins. now.
Finally, my replacement instructions suggested cleaning out your machine and removing the lint and other burdens which probably overloaded the fuse in the first place. So I bought one of those specialized lint brushes to clean out the trap and the exhaust hose and vent.
Your instructions were brilliant! I bought the fuses for $20 and saved myself an $88 service call! Cleaning the lint trap with every load is NOT sufficient. When I took off the front panel of the dryer and dismantled the entire trap that leads to the blower, it was packed solid. The guy at the Maytag store said that would likely be the cause of the blown fuse. I'm sure it was. The dryer is running more quietly and efficiently than it has since I bought it!
My dryer wouldnt start at all either. i own the maytag model number PYE3300AYW.. i went through the run around of it might be the door switch and tested that it was fine. Then they said maybe the timer...............nope that was fine. Finally a little thermostat fuse that is all the way in the back on the side of the heating element was bad! so i had to take everything apart to get to this fuse that caused my dryer not to start but now it runs perfect!
I would start by checking the power to the dryer there should be 110 volts ac from common to L1 and 110 volts ac from common to L2 and 220 from L1 to L2. If you are not familiar with either AC current or a volt meter call a tech. if that is good there is often a high temp safty thermostat some where on the unit. if it doesnt read continuity on your ohm meter than replace the safty thermistat. how ever there is usualy anohter underlying issue. check your venting and make sure it is clear. that is the most common reason for a safty thermo to fail. hope this helps
-Check the power to the dryer (between L1 and L2 should read around 240 V AC, L1 to the White (neutral) should read 120 V AC, L2 to the White should read 120 V AC)
-check the thermal fuse on the right side of the heater assembly (use a continuity meter, should be buzzing or on the Ohm meter "0" Ohm)
if not replace it
-if the thermal fuse was broken, clean and check inside your dryer the went passages and your went pipe is the next thing to blow out.
-if everything looks clean assemble your dryer and ready to rock!
MAYTAG BRAND IS NO LONGER THE QUALITY BRAND THAT IT WAS ONCE. THIS COMPANY BRAND WILL BE LIKE GM AND CHRYSLER. MAYBE IT IS THE YUGO ALREADY. DO NOT WASTE YOUR MONEY ON MAYTAG APPLIANCES.
It is the little thermo fuse next to the heating element. It keeps the dryer from coming on if it over heats. It is a one time fuse.
I have a Maytag SDE3606AYW and the light comes on but the dryer won't. The door is closed the plug is in correctly braker box is ok. What could be the problem.
Mine is not currently running. replaced thermostats 2 yrs ago( it is 8 yrs old and used very often)
Guess i will have to replace these again. My wife thinks as long as she can cram the clothes in, it should be ok. I quit trying to tell her she is overloading it and I will continue to fix it as when it runs (which is almost every day )it runs great. I've owned a couple of others over the years and would buy this brand again. model PYE2300AYW
My dryer does not work at all
thanks once getting into the dryer a little deeper I found that the duct work from the front of the dryer was packed with lint.I would think this would cause it to overheat.
The Dryer does not turn on, I am not sure what thermostat the other solutions were talking about near the heating element that might have failed I have a thermostat on the top looks like it is mounted upside down located in the reaer of cabinet behind the drum. I was hoping to find a reset switch but apparently there is not a reset switch on the Performa model # PYE2200AYW
Thank You
dryer won't come on light is on fuse os ok and power to dryer ,the timer knob truns but won't turn on the dryer. can you help?
Maytag Performa electric dryer won't start. Breaker is on, dryer is plugged in, door is closed and when I turn the timer switch and press it on, NOTHING! Hi-limit switch and fuse are ok for continuity. Is the problem with the switch itself, or is there some other cause?
Maytag Performa electric dryer PDET920AZW (15 months old) Dryer simply quit. Trusty old Maytag repairman came and replaced the thermal fuse. The dryer quit after one more load. I found an online parts appliance repair (point&click) ordered and replaced the thermal fuse, thermostat and cycling thermostat. Same problem - the dryer runs hot then quits. also noticed that the dryer will not run on air fluff. Could it be either the dryer timer or the 4 position temperature switch OR IS THIS A LEMON MODEL!!!
My dryer will not start at ALL
my dryer won't start.It quit in the middle of a load.It did not get too hot.
Have checked breakers and plug,and made sure the door was closed good.
My dryer stopped in the middle of a load.I have checked the breakers,and plug,but it still will not start. HELP!!!
My dryer is a little over a year old and will not work. Reset the breaker and still nothing. When you try to turn it on there is a buzz noise which eventually stops altogether and makes no noise when try to start again. It smelled a little like it was burning.
Has anyone answered the people?
