Seagate Python SCSI 04106
I have one of these drives in my Dell PE 1300 and was in Windows 2000 Server edition and it used to work flawlessly. I was in process of moving, and it sat in storage in my Aunt's garage from March 31st until the following July (1 year ago) but like a dummy? I had forgot to take the tape out. I have done all the steps I have read> http://en.community.dell.com/support-forums/storage/f/1216/p/19527699/20457959.aspx and I was able to manually eject it, but now it will not take a tape. I have just the past few days, reloaded OS to Server 2003 R2 and still have the same problem, hence me suspecting it is not software or firmware related anymore...but something is still "inside" stuck? Thanks in advance, Jim
  • 3,799 Answers
A garage is a damp place, the best thing to do is leave the unit in a warm dry place and allow the unit to dry out completely. This should fix your problem, although the damp may have caused damage to the delicate tape heads and bearings.
Posted on Oct 15, 2013
3 Suggested Answers
6ya staff
SOURCE:
LRL Computer
Fred Steinberg
  • 65 Answers
SOURCE: dell optiplex gx-260 slow performace
If this is happening on all workstations you should look at your network settings and verify that your DNS settings are correct.  Also look in the error logs on the server to see if it is fillingup with system or application errors.
Posted on Oct 18, 2007
Abhinav Jha
  • 81 Answers
SOURCE: Webpage error details
uninstall and reinstall internet explorerby add remove programs
Posted on Mar 24, 2010
How can i istall windows server 2000 on Dell Poweredge T300
Windows 2000 is not supported on this machine. The closest you could get is using a hypervisor XenServer or VMWare ESXi and then installing Windows 2000 on a virtual machine.
Jan 26, 2015 | Dell PowerEdge T300 Server
I'm trying to start Microsoft Windows Server2003 from USB Hard Drive on Dell PowerEdge 2600 Server.
Dell provides lifetime tech support for all PE servers. Call them at 800-945-3355 and give them the service tag or express service code from the server. If it can be done, they will tell you how.
Feb 29, 2012 | Dell PowerEdge 2600 Server
I have dell 4600 pe serveri want to install Server2003 os i have configured raid 1 on the machine every thing is fine but! on boot process it display message no Boot Device Found Press F1 to continue F2...
The hard drive needs to be set as the first SCSI ID device boot device..
The hard drive needs to have the jumper set to SCSI ID 0, the CD and FDD can be set to SCSI ID 1 and SCSI ID 2. No SCSI devices can have the same SCSI ID number unless it is on a different SCS controller.
Jul 01, 2010 | Dell PowerEdge 4600 Server
Will not complete boot up into windows 2000. Has worked fine for years, other day there was a power outage and next day we came in and the server was blinking at the final stage of boot process before...
I would recommend you boot to your 2000 CD, load the RAID driver for the CERC, and go to Recovery Console and perform a CHKDSK /R and FIXBOOT at the command line. Sounds to me as if Windows has been damaged. Is the power light amber or blue?
Apr 01, 2010 | Dell PowerEdge 1800 Server
Poweredge 1800 server
Hey,
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
http://support.dell.com/support/downloads/
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Thanks,
Ekse
Jun 03, 2009 | Dell PowerEdge 1800 Server
I'm having some trouble with a dell poweredge 2650 I bought off eBay.
You are not too clear, however I'll take a guess ..
1) Booting from CD ... older CD drives fitted to PE26xx range do not recognize Windows 2003 bootable install CD's .. the TS-L462C (a laptop drive) should be compatible with the PE 2650 (I know it works in my 2600)
2) Installing the Operating System onto the PERC SCSI Array drives .. a total pain .. with older OS (Windows 2000) you can use the 4 x floppy disk set to install and hit (F6 ? as I recall) to tell it to 'load a 3rd party driver' ... get the PERC drivers from the Dell site.
Alternative = toss the useless Tape Drive and install a set of SATA drives in the same space (a 3 drive Hot Swap caddy eclosure will fit = Icy Box or StarTech) .. you will need a PCI RAID card (such as Si3124) since the M'Bd has nothing but a combined floppy/TapeDrive IDE interfafce.
3) Finally, be aware that this is a SERVER level box .. spare parts & Dell 'official' upgrades are going to cost you an arm & a leg = and don't even ask what the special 'ECC parity' Memory sticks cost :-)
Jan 22, 2009 | Dell PowerEdge 2650 (PE2650BB) Server
Dell Inspiron 1300 can't connect external monitor
I was having the same problrm for my dell inspiron 1300. It is not FN + f5. It is fn +f8. Notice the Crt/LCD...
Jan 04, 2009 | Dell Inspiron 1300 Notebook
Can i add 142GB of hard disk on Dell PE 2600 motherboard
You can always add more storage to a server, as long as you have enough internal connectors in the server. You can also purchase another scsi or sata backplane to add more ports if you're out of internal connectors.
You may also want to look into a SAN or NAS device to offload some of your not too frequently used data. Many SAN devices give incredible performance with pretty good scalability.
Steven
Sep 16, 2008 | Dell PowerEdge 2600 Server
Beeping PowerEdge 1300
When a Dell server beeps in every 3-5 second that mean it comes from Raid controller.
Dell calls PERC Controller.
It usually reason of a disk failure.
Install open manage server administrator on your server.
See which disks are failed ?
Try to run Power edge diagnostics on the failed disk.
If it passes the test reseat the disk.
if it fails disk has to be replaced with a new one.
If passes the quick test, reseat the disk and update disk + perc firmware and driver to the latest level. that will solve the problem!!
99% beeping comes from perc controller because of a failed HDD
cheers
Aug 18, 2008 | Dell PowerEdge 1300 Server
Dell inspiron 1300
go to the site on net and down-load bios and chipset of the system then installed it on the system.
May 29, 2008 | Dell Inspiron 1300 Notebook
Computers & Internet Logo
Ekse
Marvin
Marvin
