SOURCE: need to find cleaning solution for clr2060 ice maker. I live in
I recommend using National Chemicals Nickel Safe Ice Machine Cleaner. Catalog Number NS16OZ.
****Warning**** this is a professional product!
Refer to the units instructions on how and when to use the cleaner. Directions for the cleaner amounts are on the bottle.
Go to a local resturaunt supplier and ask if they have any.
Hope this helps and please rate this!
SOURCE: U Line CLR60 Ice Maker gets stuck in harvest mode & melts ice
have you got the equipment to change this solenoid valve? you will need a vacuum pump to evacuate the system once you have changed the valve, and the equipment to charge the system with refrigerant (gas).
SOURCE: uline ice maker clr2060- makes ice continuously,
This is a problem when the thermistor in your icebin is not being satisfied.Now there is a break in the serial number to find out if you have a thermistor or a mechanical thermostat. If the serial number is before 03 (first 2 digits is the year)and the 2 digits between the dashes is 11(the month) the replace the bin thermostat. If newer then you need to replace board and thermistors.
SOURCE: Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
SOURCE: uline clr2060 produces little ice
First thing is to remove the water from the trough. Pull out the grey standpipe in the back of water trough. Then see if the grid has a good frost pattern.If the frost pattern is NOT even then you need a service call to check the sealed system. If you do have a frost pattern check to see if the water is splashing over or make sure the drain is in the bin drain hole.If water is getting in the bin then the ice can melt as fast as it makes it.Make sure your cleaning with U-line cleaner.
