ASUS P5VDC-MX Motherboard Logo
i
istaiyakkhan Posted on Oct 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Driver vga chipset - ASUS P5VDC-MX Motherboard
Michael Green
Level 3:
  • ASUS Master 3,799 Answers
  • Posted on Oct 14, 2013
Michael Green
ASUS Master
Level 3:
Answers
3799
Questions
0
Helped
600368
Points
10177
Ask a question. It isn't difficult, you tell us what the problem is (in as much detail as possible) and then ask us a question about your problem. We don't read minds, so if you don't tell us what you want, we can't help- CAN WE?
I bought G41 D3C biostar motherboard and cannot install window xp 2002 sp3 nor window 7 always error while coping window file
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
or you might not have the correct drivers
http://download.biostar.com.tw/upload/Driver/Chipset/Intel/VGA/EagleLake/VistaWin7_32/win7.exe
http://download.biostar.com.tw/upload/Driver/Chipset/Intel/VGA/EagleLake/VistaWin7_64/WinVista7_64.exe
http://download.biostar.com.tw/upload/Driver/Chipset/Intel/VGA/EagleLake/XP32/Setup.exe
http://download.biostar.com.tw/upload/Driver/Chipset/Intel/VGA/EagleLake/XP64/Setup.exe
hope this helps
Vga driver vista for extensa 5620-6830
Your VGA driver is probably included in your chipset driver download
http://global-download.acer.com/GDFiles/Driver/Chipset/Chipset_Intel_8.7.0.1005_Vistax86.zip?acerid=633646463266135393&Step1=Notebook&Step2=Extensa&Step3=Extensa%205620&OS=V08&LC=en&BC=Acer&SC=PA_6
Here is a download link for the chipset download (which usually covers alot) Just simply download and install.
17helpful
I want VGA drivers for my IBM NETVISTA P4 computer or send me information about that VGA driver.
you should look for the chipset. if its intel i845 chipset you may try win2k_xp141.exe for vga driver. it works for :
* Intel(R) 830MG Chipset
* Intel(R) 845G Chipset
* Intel(R) 855GM Chipset
* Intel(R) 845GL Chipset
* Intel(R) 865G Chipset
* Intel(R) 845GE Chipset
* Intel(R) 852GM Chipset
* Intel(R) 855GME Chipset
* Intel(R) 845GV Chipset
* Intel(R) 852GME Chipset
43helpful
3answers
VGA driver for PM8M3-V H chipset.
you can download here
http://drivers-download-driver.com/tag/pm8m3-vh-vga-drivers
regards
There is no sound drivers are installed and all text is shaded
Hi
This is the software issue. Need to install the appropriate software to reslove this issue.
1.Ethernet controler - Need to install the chipset driver and the Lan driver
2.Pci bus device - Chipset driver
3. sm bus controller - After installation of the Chipset driver - Right click on the sm bus controller and update the driver - select install from specific location - i will chose the location- Select the model and hardware type as thermal sensor
next - follow the instruction.
4. video controller - Need to install the VGA or Display driver
5. video controller (vga compatiable) - Need to install the VGA or Display driver
With regards
[email protected]
10helpful
Asus p4p800s.x motherboard drivers
Hi bernard_in_c, you can download the audio & VGA software directly from Asus. Click on the link below. Choose your operating system from the pop-up window than click search. The driver download page will open: http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P4P800S-X An Asus pop-up window will open & you must choose your operating system from the dropdown menu. Than click the Search button.
Click the + sign next to the device you want to download. With the Asus P4P800S-X motherboard there is not a separate VGA driver. (The VGA graphics card is a PCI VGA integrated card).
The VGA driver is part of the chipset software. Open the + sign next to Other. Download, Intel(R) Chipset Software Installation Utility 5.0.2.1003 for Windows.
By installing the chipset driver software (In a running system of windows), it will over-write all chipset drivers within your system. It is possible your windows may become wacky. Normally the chipset driver software is installed right after installing windows. (A fresh install).
Make sure you have the bios settings set correctly for the VGA/PCI. Open your manual to page 2-18 & set up per page 2-19. Go to Graphic adapter priority set this to, [PCI/AGP]. Next set the amount of system memory you want the graphics card to use. At the bottom of page 2-16, leave AGP/PCI frequency set to, [Auto].
If you run into any troubles, just post them here.
Good luck bernard_in_c!
Mike
10helpful
11answers
VGA Adapter
Most new laptops shipped with Vista use drivers that use the new WDDM instruction set for Aero. XP has one less D, WDM. This usually means that generic drivers MAY be the only way to get it to work. There are too many packages of the Satellite A135, if you gave me which one I can point you to the correct chipset.
Regardless of the OS the laptop was shipped with, you can usually find drivers for any OS based on the video chipset used. For example the A135-S4827 includes an Intel GMA950 video chipset. googling your model + video chipset will almost always get you a driver.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
