Kenmore Elite Oasis 27052 Top Load Washer Logo
Posted on Apr 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore elite washer problem
Hello, my washer stops in the middle of the cycle and doesn't drain the water. The display shows: Ld, or another time Fl. Do you know what it means? I appreciate your help kenmore elite oasis canyon cap washer wont drain code ld appears do i really need to take apart drain in back and check pump the waters gonna come pouring out is there easier way can i access tub to check drain from inside tub from top of machine
  • 1 more comment
  • Anonymous May 12, 2009
    washer will not run at all. It flashed LD on the last two cycles prior to it's (hopefully) rest period. Now I need to know how to get it up and running again. Any help out there????????
  • tbex May 18, 2009
    At first, the lights were on but nothing would happen. After I unplugged it and plugged it back in, the washer started working, but now it stopped in the middle o a cycle and is full of water!!! How do I fix this???
  • Anonymous Mar 21, 2014
    How do I get inner tub out of kenmore oasis washer
Anonymous
Level 3:
Genius:
  • Master 1,122 Answers
  • Posted on Apr 24, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1122
Questions
5
Helped
316617
Points
2771
You can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
  • Anonymous May 26, 2013
    Did that and nothing was in the hose or pump? What else could it be?
My washer stops in the middle of the cycle what does this mean Flashes LD Error
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Kenmore elite washer does not finish the drain cycle and it shows a LD error and does not finish washing.
LD error is for long drain. The pump filter in the pump assembly is probably clogged. Remove front lower panel, pump assembly is in the front with a cap that unscrews. Once cap is unscrewed you can slide out the filter and clean. Remove as much water as possible from basket before taking off pump cap or else water will come flooding out when filter is removed. Reinstall and run drain spin cycle. Should drain ok.
4helpful
3answers
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
2answers
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
1helpful
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
2answers
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
1helpful
Click on kenmore (below FIXYA)on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, u hv your manual on line.
Displays ld
Hi, how are ya?
Hello, LD stands for long drain.
If all the water isn't out of the unit within a certain time, the ld will flash.
Could be 2 things.
1) There's lint stuck in the pump preventing the water to drain properly or
2) You're using too much soap causing lots of suds also preventing the pump from draining properly. If this is the case, what you need to do is run the washer on full load with no detergent and clothes. Let it go thru the cycle and get rid of eccess suds. This is most likely your problem.
Thanks for using Fixya
Alexander
vince
