My GE side by side doesn't maintain temperature as cold as it should. The doors have been replaced by the recall. The ice maker usually ends up making a giant lump of ice, it seems as if there is always moisture on the sides not ice crystals and water droplets on the wire shelves. Anything that comes in a box like frozen waffles the box gets soggy. The GE oven service technician says to maintain temp setting at 5 of 10 but do not notice any difference at any setting.
The door seals are letting air in or the seal at the ice dispenser has gone bad and is letting outside(hot) air in and it is the cause of the moisture.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
SOURCE: Gss25wgsd bb model number
Mick...there may be any number of reasons for this. First, check for a bad door gasket. It must be clean and fit snugly around the unit. Use a piece of typing paper about 2 inches wide to pull through. It should pull with some resistance anywhere you try. If it is gappy, humidity can leak in.
Next, make sure the condenser coils are clean. Third, how cold is your freezer? Is should be about 5 degrees or so if it is kept closed for about 6 hours or more.
Is the ice maker clean and not overflowing? Many units can be removed and cleaned out.
You may have other issues...start with these.
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
SOURCE: GE Artica side by side
did you also change the temp. sensor that's on top of the evap coil?if you didn't you'll smoke every board you put in there,on some models when you change out the board you also have to change out the evap fan motor that has the sensor connected to it,but i cut out the sensor and connect a new one to the wires and keep the fan motor,also you have to check to see if you have a wire in pin one of the 9 pin connector,it tells you in the instructions,if there's a wire in there you have to cut it,the sensor part number is wr55x10025,but check that with your parts store,it looks like a white bullet and if it has a black like gasket on it where the wires connect to it that's your problem if you changed out the board and didn't change the sensor.let me know how you make out
SOURCE: model # FRT18IL6DWP Moisture
Hi, If you are hearing a clicking or buzzing then check out the last two tips.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
SOURCE: I have a GE Profile
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
