Question about Daewoo FR-064R Refrigerator With Ice Box
Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
I have a Frigidaire refridgerator with a filetered water and ice maker system. Recently we discovered that there wasn't any water coming from the water filtration system and no ice was being made. I finally got the water to work by changing the filter and making sure the Household and and Saddle water lines were on. After all that, I noticed that there was air, no, it actually looked like there the water wasn't fully going through the ice maker water line. I figured it might be because there was something wrong at the Ice Maker Inlet value or that there was frozen ice clog coming through the tube that fills the well. Sure enough - there was frozen ice in the tube, I think because there wasn't any water flowing through the fill tube. I finally melted the ice with a blow dryer and the ice slid out. Yet, the water still did not come in. Onto the ice maker inlet at the bottom of the applicance. I unscrewed the inlet only to find out that there wasn't any water coming out. Yet, there is water being fed to the water filter. I think I narrowed down the issue to the ice maker inlet valve. What do I do next?
  • 10 more comments
  • Anonymous Dec 28, 2007
    I actually have a Whirlpool ED5CHQXKT03 and I am not getting any water in my ice maker so no ice. I messed with the water supply valve and that doesnt seem to be the prob. I am going to look at the line inside of the freezer to make sure it isnt frozen in the freezer.
  • phyllis-2 Nov 09, 2008
    I have Estate refrigerator and it is doing the same thing with the ice maker. There is ice in the tray and will not dump and no water is coming to the ice maker. I still water in the door of the refrigerator. What do I do?
  • Anonymous Nov 09, 2008
    have water to watervalve,but no water to icemaker
  • Anonymous Nov 18, 2008
    MY WATER IS WORKING BUT ICE MAKER ISNT GETTING ANY WATER IN IT
  • ebennettscot Dec 18, 2008
    we have exactly the same problem
  • Cnewm Dec 24, 2008
    The water is not filling in my kenmore 50532301 ice maker. The water through the door works fine. Got any suggestions...
  • Anonymous Jan 05, 2009
    Frigidaire FRS20ZR Not making ice, apparently no water getting to ice maker. Water dispenser works. Water solonoid sounds like it is opening.
  • Anonymous Jan 24, 2009
    the ice maker is not making ice and water is going throught because the water dispenser is working.
  • Anonymous Feb 04, 2009
    Help water but no ice fridg is only 5 years old??? why isnt it making ice Whirlpool model no ED2GHGXMQOO
  • Anonymous Mar 04, 2009
    The water is not filling in my roper ice maker. The water through the door works fine.
  • roadtohana Mar 24, 2009
    I can get water out of the dispenser but it will not make any ice. What can we look for to try and fix it on our own?
  • Anonymous Mar 19, 2014
    the filter has been changed the water comes out but the ice maker doesn't fill up to make ice
Hi there when i bought a similar frezer with ice box i called for assistance only to find the water pressure going in was not high enough after it had been through the filter the easiest way to solve the problem is to get rid of the filter,
Posted on Aug 30, 2009
  • 447 Answers
Very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 700 Answers
SOURCE: Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
take the line off of the solinoid valve and check to see if there's a screen in the valve. that could be plugged with debris.
Posted on Dec 20, 2008
How to repair Refrigerator ice maker that not making ice
Any chance you may have the model number of that refrigerator that you're having problems with the ice maker?
Appliance 911 Sea Breeze there are some ice makers that you can repair but as far as cost is not worth it ice makers wear out after several years there's a lot of work involved in making ice just replacing the part that broke doesn't fix the rest of the Ice maker
Sep 01, 2016 | Frigidaire Refrigerators
Newly installed ice maker two days old, not dropping ice, frididaire refridgerator
Ice maker under warranty have them look at it will not cost you anything.
Aug 29, 2014 | Kitchen Appliances - Others
My Frigidaire side-by-side refrigirator is not making ice
Here is a simple tip that may help you decide what is causing this problem. If the ice maker has no ice cubes in the slots fill with tap water and allow water to freeze. If the ice maker cycles and drops the ice into the ice bin and then does not refill with water the problem is the 241734302 Water Inlet Valve (providing that the model number above your post is correct) If the ice maker only sits there with ice in the slots and does nothing the ice maker is the problem 5303918277 Ice Maker Assembly Testing the water control valve is as follows. I will be here to answer any questions you may have, Thanks Sea Breeze
Apr 26, 2013 | Frigidaire FRS26H5AS Side by Side...
Leaking water in side always
If the water leak is down the back or ctr its the drain line going to the underside of the fridge. If its down the side where the ice maker is its the ice make is not level if no ice maker your tray under the freezer may be leaking instead of draining.
Jul 20, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice maker is not working.
Ice maker has built in thermostat that turns cycle on at around 10 degrees F. If freezer temp does not reach that point the ice maker will not cycle. So either the freezer is not cold enough or the thermostat is faulty.
Make sure that the ice maker motor that turns the cams and controls the various stages is also working.
Apr 08, 2017 | Frigidaire 20.6 cu. ft. Top Freezer...
Dec 20, 2008 | Frigidaire FRS26R4A Side by Side...
Ice with Sediments
in the water supply line to but well before the refrigerator fit a ceramic water filter
that has a filter so fine that many germs cannot pass through
Nov 26, 2017 | Frigidaire FSC23F7DSB Stainless Steel Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Jenn air model JRSD209T
If you have a cold enough temp in the icemaker a heater should then kick in to warm the plate and a motor then turns and drives the ice out. The ice maker modules can be repaired, but the checks need to be carried out by fridge guys. Alternatively you can replace the whole module but this can vary in cost quite dramatically. Hope this has been of some help.
Sep 11, 2007 | Frigidaire FRS23H7C Side by Side...
Daewoo FR-064R Refrigerator With Ice Box Logo
2,595 people viewed this question
Top Daewoo Refrigerators Experts
jasbo
jasbo
john h
roeb
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
