First try drain then release. If does not work them power off for one minute. Turn on then try drain and spin cycle again.
The door is probably locked, because the water is still draining. If this is not the answer, the the suction between the dor and the opening is too strong and you must get it weakened by a professional. There is one more solution, and that is to unplug the machine, reset it, and then try opening the door.
SOURCE: bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
SOURCE: my LG washer door wont open. Model is wd-14316RD.
There will be a delay of about 1 minute before it will open, this is normal. However if it will not open at any time try turning off at the power point, other than that you may need to get someone to look at it.
SOURCE: asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
SOURCE: bosch wfl 2050/2060 washer door is jammed and will not open
talked with bosch rep-- said there is no manual door release
You first of all need to
check the pump filter. This is
located at the bottom front right of washer. Look for a drop down flap or cover, once
located, unscrew filter anti-clockwise to remove and clean. Of course be prepared for a lot of water and
junk. The pump itself is directly behind
the filter housing, check there to see if anything is stuck in the plastic blades. It should turn freely. Your washer door will not open if there is
water in the washer, just some kind of precaution, so don't force the door.
Pl click if helped..
Hello &
Welcome to FixYa
E13 error in
your Bosch WFMC washer is a drain error and is displayed when the drain time
exceeds & the washer is unable to drain so the door won't open sometimes
when this error is displayed. You will have to clean the drain trap in the
bottom right hand corner. You can stick a straighten paper clip in the access
panel located inside the front bottom panel through the whole and then turn the access
panel counter clockwise to unscrew the plastic drain cap behind it. After
everything is cleaned and the error returns then replacing the drain pump is
recommended repair. Please get back to me if you have any other questions.
Kevin
