Is it "defrosting" the food or unable to keep it frozen? Probably unable to keep frozen. Many possible problems. 1. Defrost element bad and evaporator coil is iced over, or 2. Failed evaporator fan inside freezer, or 3. Low freon causing iced up evaporator coil....Do you see any ice build up on the back wall of freezer? Do you hear the freezer fan running or not? Take a look and get back to me.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
SOURCE: Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
SOURCE: Kenmore Model # 596.735032.. Fridge is cool, Freezer is not freezing
After pulling the fridge away from the wall and removing the lower right hand panel I noticed that the compressor (big round black ball with copper tubing) was not turning on. I also noticed that there was a ticking or popping sound comming from it every couple of minutes or so. After doing some research online in numerouse forums I decided to try and replace the overheat relay that is attached to the compressor. It only took maybie five minutes at most to change it and the compressor is now working with nice cold air comming into the fridge and freezer. Hope this helps someone else with the same problem.
SOURCE: Fridge and Freezer do not keep foods cool
Samsung rs2630ww i have had endless problems i have had it replaced 4 times. red hot center and side panels i have had 2 condensers burn. the problem is that it is simply badly designed!
there is not enough air flow . so if it has any restriction it kills the unit. a Samsung tech told me off the record these units are all problematic! of course he love it at 200 an hour.
SOURCE: freezer defrosted completely. fridge is barely
The compressor relay is bad on the main control board . Unplug the refrig and pull the refrig out and remove the 8X10 small panel on the back . You will see a blue plug with 3 larger (120v) wires going to it . Remove this plug . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . (this is on the plug NOT the board ) . Using a short piece of insulated wire , with about 1/4" stripped off both ends , insert 1 end into wire1 and the other into wire3 . Plug the refrig back in . This will start the compressor to verify the main control board is bad . Pt # WR55X10942 .
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
