E000245 Error Code in IR6000
SOURCE: Error code E000245-0010
KABRaji, Your copier print board is faulty or some loose wiring. also posible if some fault in counter pcb
SOURCE: machine indicate errorcode E000245-0010
E 000245-0010, soft counter board problem,Check this board, maybe its missing or it is not inserted properly re insert it other wise it is corrupted, this board cannot be interchange as the machine serial number is embedded on it ,you have to consult authorized canon agent on this(soft counter corruption)
SOURCE: paper jam and error code e012 on ir6000
You could very well have a worn registration clutch, it's behind the the gray roller that sits to the right under the drum. Good luck! If that doesn't do the trick you may have to change your transfer settings in service mode
SOURCE: error code e000020 in ir6000
E020
General condition
1) Is the developing assembly locking plate mounted correctly?
NO: Mount the plate correctly.
General condition
2) Is the shutter releasing member of the hopper mouth mounted correctly
to the developing assembly locking plate?
NO: It is likely that the inside of the hopper is clogged with toner. Remove
and then mount back the shutter releasing member to remove
the clog, or replace the hopper unit.
General condition, Developing assembly toner sensor (TS1)
3) Is the developing assembly adequately provided with toner?
YES: Check the developing assembly toner sensor.
General condition, Hopper toner sensor (TS2)
4) Is the hopper adequately provided with toner?
NO: Check the hopper toner sensor.
Hopper connector, Hopper supply motor (M10)
5) Is the connection of the hopper connector normal?
NO: Connect the connector securely.
YES: Check the hopper supply motor.
