Nikon N2020 35mm SLR Camera Logo
A
Anonymous Posted on Oct 08, 2013
Service manual wheres the power button now that i have batteries in my camera?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on May 10, 2014
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10432035
Points
622693
There is no power button. Simply press the shutter release button halfway to turn the camera on. The camera will shut off after a few seconds of inactivity.
My camera doesnt allow me to take photos, the lens doesnt work.
Most of the lens issues due to mechanical problem. some of the causes are dropping the camera.
Hard shake like keeping the Camera in the hand and jump through steps, Moisture condensation, Insufficient battery.. etc If If you feel that the issue is not with the above reason, try initializing the Camera. To initialize the Camera, please use the Initialize option under the setup 1 Menu.
If the issue persists, perform a power reset of the Camera.
Performing a manual power reset Turn off the camera. Remove the battery pack. Remove the button-sized lithium battery. Allow the camera to remain without power for 30 seconds. Reinsert the button-sized lithium battery. Reinsert the battery pack. Turn on the camera. If the issue persist, service is required.
Jan 07, 2011 • Cameras
1helpful
I turn camera on and this error comes up. turn the power off and back on again. I try this with no results.
Solution
sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. Click the Repair & Status link on this page for available service options.
https://eservice.sony.com/webrma/web/index.do
Hi, The shutter on my sony dsc - p73 will not open all of a sudden is there any hope of being able to sort this?
I'm sorry that the shutter of the sony dsc - p73 will not open. I suggest that you perform a power reset and check the operation.
If the issue is not resolved, service will be requred.
Background all dark
Try to reset the camera through the menu.
http://esupport.sony.com/US/perl/model-home.pl?mdl=DSCT1&LOC=3
The above is the page for your camera.
Solution
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
1helpful
2answers
When I turn it on the screen stays black until I
  1. Ensure the camera is turned on.
  2. If applicable, ensure the lens cover has been removed before taking pictures.
  3. Ensure the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. NOTE: Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon [FIG. 1]. This button could be a standalone button or incorporated as one of the control arrow buttons depending on the model of camera.
  4. If operating the camera with a battery, ensure the battery is fully charged.
  5. Ensure the battery is inserted properly in the camera.
  6. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
  7. Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
  8. Perform a reset procedure on the camera.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony Service Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Try to reset the camera to original settings:
How to reset a Cyber-shot® digital still camera back to original factory settings. Solution
Sir, Shutter of my Digital camera Sony Cyber-shot DSC-P72 is not closing / return to original position completely. I have tried with changing the battery too. Every time that I do power on the massage...
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C91134&fes=true&mdl=DSCP72
Try doing a power reset:
Solution
Region
sp.gif sp.gif Canada Latin America United States Products
sp.gif sp.gif Cybershot Digital Still Camera Last Modified Date: 03-04-2010sp.gifID: C265373
Where do you put 3 AA batteries in the Disney Pix Click Wizards of Waverly Place digital camera? I can only find location to put 2 AA... and camera will not work.
  • They all seem to go in the same place. - some only seem to use two - this one uses three
The camera is powered by 3 AA batteries. Only use the battery specified by the manufacturer.
  1. Lift the rubber USB interface cover on the bottom of the camera and gently press the lever to the left.
  2. Lift the faceplate off completely and place it to the side of the camera.
  3. Insert the batteries using the battery polarity symbols (+/-) as a guide.
  4. Replace the faceplate by gently placing it back on the camera body.
  5. Replace the rubber USB cable connection cover on the bottom of the camera.
  6. Turn the camera on by pressing the Power button. To turn the camera off, press the Power button again.
  7. Note: If the camera is not used for one minute, it will automatically shut down. To restart the camera, press the Power button.
2helpful
My DSC-W120 Sony camera won't turn on OR remain on. If I remove the memory card and the battery and reinsert them, the power might come on for 1/2 a second. The battery is fully charged.
Date and time mode
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESETbutton or Initialize option in the menu. These cameras require a manual power reset.
Cat knocked my digital camera off the desk now the screen is blue
Try reseting your camera
  4. if you dont have a reset button try the manul reset below
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. hope this helps
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
