Goodman GMS90703BXA Heater Logo
David Quincy Posted on Aug 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Goodman furnace GMT115-5B Turn fan to on on
Goodman furnace GMT115-5B Turn fan to on on thermostat blower comes on Circuit board blows 3am fuse immediately when furnace turned on. Checked all safeties with ohm meter to ground. No problems. Took wires all off the safeties and eliminated them one by one. When I got to the limit switch immediately blew 3 am fuse. Bypassed limit switch still blew 3 amp fuse. Replace circuit board?
Thomas Woodburn
Level 3:
  • Goodman Master 2,638 Answers
  • Posted on Aug 14, 2017
Thomas Woodburn
Goodman Master
Level 3:
Answers
2638
Questions
Helped
1250511
Points
7008
Bypass the tstat first but that's where I'd be leaning.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
5 Related Answers
Anonymous
  • 1420 Answers
  • Posted on Jun 10, 2008
SOURCE: keeps blowing the fuse.
Most likely it's near where the wires got weed wacked outside. Follow the wires from the indoor unit to the outdoor unit. Look for any damage along the way. Also follow any thermostat wires you can find and inspect them. Sometimes where they enter into both the inside and outside units they frey on the metal casing. I hope you find something. Otherwise, you may have a bad transformer sending the wrong voltage to components.
Anonymous
  • 29 Answers
  • Posted on Jun 21, 2009
SOURCE: Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Anonymous
  • 232 Answers
  • Posted on Nov 06, 2009
SOURCE: I have a goodman GMP 125-5 furnace. I have
sounds like the primary limit typically behind the gas valve its larger then the others, rectangle in shape with 2 wires going to it. be careful if your bypassing limit this can create a very hazardous condition
Frank Bryant Wetzel
  • 456 Answers
  • Posted on Jul 16, 2010
SOURCE: fuse blow each time I turn on air check for
disconnect the thernostat wires from the control board. Put a jumper wire between R & G put door back on and turn on power. Blower motor
should run, if it blows the fuse then you have a direct short between R &
G at the board. Do this with R and W(heat) and R & Y(cool).
By disconnecting the thermostat wires and reinserting them make sure that they do not touch when inserted into each terminal. If it still blows
that little 3amp fuse when jumpering between each sequence as mentioned above, then I think your board is bad. When Jumpering out the Y terminal you will have to have the AC wires still hooked up. If it
blows the fuse in that sequence. Disconnect the wires out at the condensor.
You mat have a bad contactor at the outdoor unit.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Dec 02, 2010
SOURCE: GMT070-3b goodman furnace. Vent fan wasn't
Look on the inside of furnace door/front cover it tell you what the code one means. It sounds like you have a thermostat problem.
Blower on furnace not working
Make sure your circuit breaker hasn't tripped to your furnace. Make sure your door panel to your furnace is installed right. There is a door switch that has to be depressed to complete the circuit. Also turn thermostat to fan on and see if fan comes on. If those two things don't work it will have to be trouble shot by a respectable HVAC technician. Could be your Indoor blower capacitor, defective fuse on circuit board or defective circuit board or defective blower motor.
1helpful
Goodman a/c @ heating unit. Model #gmh80703anca when I turn the unit on it keeps blowing the fuse on the circuit panel. What could be causing this?
Several questions:
1. What fuse? 110V at the furnace? Breaker at the house? Fuse on the controller board?
2. Does the ignitor work? Do you get gas ignition?
3. Does the exhaust fan come on?
4. Does the main blower come on?
HKR-10C FURNACE BLOWER WONT KICK ON
if you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
Didn't cool and the fan on the outside unit is not turning
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Ruud IFC Furnace Blower comes on and stays running, never lites
Check on the circuit board for an automotive type fuse that is probably blown. These fuses blow because of a short in the control wiring. If the fuse is blown a lot of furnaces run the fan all the time as a diagnostic. You will have to find the short or it will just blow again.
1helpful
Yesterday the furnace was working and now doesn't come on.
You will need to have a service technician come out. It could be a fuse out on the board, a bad board or several other problems in the circuit that can only be determined by a professional on site.
Goodman furnace
2helpful
2answers
Goodman a/c blower fan will not shut off
Unhook the thermostat wires on the furnace. If the blower shuts off then your problem is either the thermostat or the thermostat wires. If it contiues to run check you high limit switches next. If all else fails you most likely have a bad blower relay. On most modern furnaces the blower relay is part of the circuit board.
Good luck
Furnace blower motor
I would check the "G" wire at the Thermostat and make sure that it has a solid connection. The other end screws on to a terminal in the furnace. Check this connection as well. This green(G) wire is what activates the 120v relay on the circuit board. You can test this by turning the thermostat to the off position and then jumping the 24v R terminal with the 24v G terminal at the furnace. if the fan comes on then the problem is in the thermostat wire or the thermostat itself.
4answers
Air conditioner blower
From your discription... I would think you have a problem in the thermostat. Does the fan run in cool if you put the fan in the ON position. Some older t-stats have a jumper between terminals that brings the fan on in cool. You will need to find out if there is low voltage power between the green t-stat wire and common in the air handler. If you have a Gas furnace the fan comes on by a temp control also there is a door switch. If the door is off the door switch will be open. and no fan.
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
