See the video attached, lube TOO the rollers bearing front +back.
see the video how to adjust the deck belt.God bless you
However if finally the problem persist, test the input voltage motor see my personal TIPS, if there are Voltage at the terminals, the motor is faulty. Measure the output Voltage from the control board
for to input to the Motor, if there are NOT voltage from output the control BOARD is faulty, replace.
SOURCE: Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove
the key and UNPLUG THE POWER CORD.
Using the hex key, turn both rear roller bolts clockwise,
1/4 of a turn. When the walking belt is correctly
tightened, you should be able to lift each edge of the
walking belt 2 to 3 inches above the walking platform.
Be careful to keep the walking belt centered. Then,
plug in the power cord, insert the key, and carefully
walk on the treadmill for a few minutes. Repeat until
the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
SOURCE: belt stops during workout and have to step offf
you need LUBE in according with the instruction manual maintenance schedule . You have a deck belt worn 2) Test the drive Belt for replace 3) Test the input voltage motor, if there are the motor need repair 4) Test the output voltage from motor board, for input main motor, if there are NOT the board is faulty.
RUN the software calibration for easy diagnose and troubleshooting. See my personal TIPS for HELP.
sincerely. God bless you
