A motor in the Ref. started to make a groan like noise.
Kenmore refrigerator model 795 Bottom Freezer
A motor in the Ref. started to make a groan like noise. I am not sure of the cause how to track down the problem.
Your help is appreciated. Thank you, Mike
Disconnect the defrost element and check with a multimeter for continuity. If there is no continuity, the element has failed. If the element is good, check the connections.
There is usually a Defrost Timer, but this uses a Defrost Sensor. Put 'defrost' into the Parts Search.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
problem may be the main pcb or evaporator fan motor. this unit has several problems. if the model# starts with a 795 it was made by LG. the er ff code is caused most of the time from frost building up around fan motor. this can also be caused by freezer liner sagging at the top of freezer causing frost build up, sears has a service flash for this that is covered by the manufacture. service flash sf46-512. iwould call sears and find out if your model is on this service flash.
The most likely cause is a bad evaperator fan motor. It is mounted in the freezer section. It blows the air up to the ref section. Open the freezer door and listen to see if you hear any fan noise.
The evap fan motor most likely is running loud due to a ice build up around the fan and the fan blade is hitting it and making a loud , irriting noise. Shut the ref off. If you are mechanical, remove the draw and the back cover, clear out the ice. Also, the ice may have been caused because the sensors-- thermistors--- are not located properly. look at the ceiling of the freezer and you see a small holder piece. the part is located there. tahke the cover off and take the thermistor that may be buried in the ceiling and pull it down and locate it in the holder, reinstall the holder. Not also, there is another one in the ref section to do the same thing
1. remove everything from freezer.
2. unplug freezer.
3. remove screws from back of freezer wall.
4.remove evaporator fan.
(you will see it at the top of the freezer wall)
5.install new one.
Thank you... I'll do that tomorrow. (After I figure out how to remove the back... looks simple enough.) Mike
