Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Tammy Underwood Posted on Oct 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sony Trinitron KV-32S36 model. It's 16 yrs old. The sound works fine. When you turn tv on the picture is off center and keeps fading till there is no picture at all. Is this the tube going out?
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Oct 03, 2013
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994472
Points
237762
Surely the emission of the CRT is going out.
5 Related Answers
Bill Heronemus
  • 308 Answers
  • Posted on Dec 24, 2006
SOURCE: sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Anonymous
  • 4 Answers
  • Posted on Jan 01, 2009
SOURCE: sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Anonymous
    • 5 Answers
    • Posted on Apr 13, 2009
    SOURCE: Standby/stereo light blinking no picture or sound
    My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!! My TV is 9 years old.
    Anonymous
    • 563 Answers
    • Posted on Jul 11, 2009
    SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
    I have over 10 years experience in electronic tech support.
    I know this isn't what you want to hear, but the problem you've described can't be fixed with
    troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
    If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
    circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
    I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
    Please let me know if I can be of further assistance.
    barbu51
    Jacques Marin
    • 566 Answers
    • Posted on Dec 17, 2009
    SOURCE: kv-32fs16, no picture or sound , red lights flash 4 times
    Hi
    In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
    It is often caused by a faulty vertical output i.c and/or related components. If you feel handy with a soldering iron let me know and i`ll help you with it.
    Hope this help Merry Christmas
    KV-HP212M83 greenish blackout blinks 2 times
    Measure B+ on the set , If normal check G2 voltage
    G2 adjustment is on the Flyback Transformer
    2answers
    Blurry & Fuzzy Picture Sony Trinitron
    Check the filter capacitor to the supply to video output card. You can locate this capacitor at the CRT base card to your Sony Trinitron. Replace this electrolytic capacitor.
    32" Sony Trinton Wega
    Count the flashes and verify that the model is KV-32FS100. The flash count will indicate the circuit in which the problem was detected.
    Thanks,
    Dan
    1helpful
    Picture Problem
    Your TV's tuner is the problem. 1st thing to try is just to sesolder its connections to the main circuit board. If that doesn't work replace the tuner. Also could put a meter on the power coming into the tuner and see if it is drooping in sync with your picture. Tuners are not that expensive to replace.
    Sony kv32s42 trinitron color tv blinking
    sounds like a bad picture tube. Picture and bright settings cranked up for a good pic? Test/rejuv with a crt tester and/or look at the Ik signal on the crt board. A good tube has 3 small pulses during blanking. The crt cathodes are checked with these pulses, pulses too low and the jungle IC will blank the drive. If the picture fades in and out I would check the filament ckt but that doesn't support the "blinks"
    Sony KV-32S36 32" suddenly stopped working, no picture or sound
    Check soldered in fuse R607 in power supply circuit =
    If open, replace it and bad converter xistors ( 2SC4834)
    Next, replace shorted horizontal output transistor w/ first Quality.
    Solder any / all bad connects,esp.horiz drive to base of horiz.
    o / p xistor. Soldering is critical or it will blow up again......
    1helpful
    Sony tv picture keeps flashing
    Top Sony Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ZJ Limited
    ZJ Limited
    matt martin
    matt martin
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
