Everest Refrigeration ESR3 Logo
A
Anonymous Posted on Oct 02, 2013
Remedy for Er3 error....... - Everest Refrigeration ESR3
What does the error code ER3 mean, on a Dri-EazPHD 200 dehumidifier?
https://www.jondon.com/media/pdf/manuals/DP-F515_manual.pdf
ER3 CONTACT SERVICE CENTER
Unit in defrost too long. Check defrost sensor cable for proper connection. If error persists, sensor assembly may require replacement. Contact service.
ER3 error code on amtrol hot water tank
Simply means hot water heater called for heat for 1 hour and never rose in temperature or reach stepping, unit automatically goes into lockout. I would reset power
3answers
Boilermate er3
is it an electric or gas or oil fired. Er3 means it is not getting up to temperature within the required time. Electrical - element bad. for oil or gas, no ignition or fuel supply.
I HAVE A MONARCH SPA AND AN ERROR CODE HAS COME UP ER3
What is the brand of equipment in your spa? From knowing the brand of equipment we can search the error codes and let you know what is going on.
Rod
US Parts Center
Jan 16, 2013 • Pool & Spa
2answers
No hot water. Display reads ER3.
Hi, If you have the book for this system, then go to the problem solving to the rear of manual. This will tell you what code ER3 means, and what you need to do to correct it.
If you dont have the manufacturer's book then try to down load it!.
All boilers and water heaters have different fault finding codes, so can-not give any more info, unless you can tell me the exact problem.
Thanks Paul.
8helpful
ER3 no hot water
Er3 means that the water is being heated for more than 1 hour without reaching the set temperature.
Need new aquastat.
ER3 Message
We had this problem and could not make it go away by refilling, jiggling the float and so on. All the controls appeared frozen during this time.
But unplugging the humidifier for 5 minutes and plugging it back in seems to have fixed it -- no ER3 message now (fingers crossed!0.
1helpful
Er3--is this an error message?
This sounds like the float switch may be stuck - giving an error message - usually these are not too hard to unstick - it is often a cleaning issue - the manual should show you where the float switch is and how to check it, but if the error message is not listed in the manual, if you are sure it is the correct manual then I would expect it to be a technicians job, else they would list the error message. Slant/Fin has sold the humidifier and PC-55 air purifier business to KAZ USA Inc. If you need replacement parts, repairs, or have any questions regarding the products, please contact them at: KAZ, Consumer Relations Dept. 250 Turnpike rd., Southborough, MA 01772 Phone: 800-477-0457 email: [email protected] also worth a look is: http://www.achooallergy.com/slantfin-ope... seems to be best forum for humidifier stuff Hope this helps :)
Top Everest Refrigeration Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you an Everest Refrigeration Refrigerator Expert? Answer questions, earn points and help others
