My kitchen aid under counter ice maker KUIA18NN has quit making ice, it is filling the reservoir with water but it is not circulating water over the refrigeration plate.
If your KitchenAid under-counter ice maker is cycling water but then powers off with the power button flashing several times, there may be a few possible causes. Here are some steps to troubleshoot the issue:
Check the water supply: Make sure that the water supply line is properly connected and the water is flowing to the ice maker. If the water supply is blocked or not reaching the ice maker, it may not be able to function properly.
Clean the condenser coils: Dirty condenser coils can cause the ice maker to overheat and shut off. Make sure to clean the coils regularly to prevent this issue.
Check the drain pump: If the drain pump is not functioning properly, the ice maker may shut off to prevent water from overflowing. Check the drain pump for any clogs or damage and replace it if necessary.
Check the water inlet valve: The water inlet valve is responsible for letting water into the ice maker. If it is not functioning properly, the ice maker may shut off. Test the valve for continuity using a multimeter and replace it if necessary.
Check the control board: If all other components are functioning properly, the issue may be with the control board. Test the control board for proper voltage and replace it if necessary.
If these troubleshooting steps do not resolve the issue, it may be necessary to call a professional technician to diagnose and repair the problem with your KitchenAid under-counter ice maker.
Does the circulating pump- pump water? Remove the hose that goes to the spreader bar and run the unit again, if it moves water as a new pump should check for blockages in that hose and spreader tube. Get back to me if this doesn't work please. Personal email address [email protected]...
First make sure your water valve is working . If so , look for fill tube that fills ice maker to be frozen. If it is frozen , unthaw tube. If its not then replace the ice maker.
sounds like you have a problem with the fill tube at the Ice Maker. remove the IM and then the back wall ( evaporator cover ) , the fill tube is probably frozen. use a hair dyer to melt ice, be careful, the hair dyer can melt the fill tube and other plastic.
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
Most likely your plastic curtain is not keeping the water in the sump area. ( I'm assuming it makes round cubes)? Look under the sump for any dripping if its a pretty steady drip replace your water curtain and the holder that's with it.
If you have a cutting grid type ice machine this is all together different and I need to tell you separately about that.
Mark, your water valve has screwed the pooch. Replace it. The part number is 2199838.
What's happening is this... the valve that fills your ice maker is by-passing a small amount of water. This water has to flow through that tube, right? When very small amounts (drop by drop) go through the IM fill tube, they flash freeze. Eventually they (the frozen drops of water) form a big block of ice inside the fill tube. This ice creates a blockage which creates back-pressure whenever the IM "calls" for water. The back pressure eventually blows the tube off of the connection behind the fridge.
You say that this happened over night... no way. If you look closely at the ice cubes that you IM has been making, you'll see that they are hollow. Hollow cubes means that your IM isn't getting enough water... (because the fill tube is blocked).
