Use a little instant start spray to see if it will start. If it does you need to clean out the carb. See what model carb you have and buy the rebuild kit online. They are 12 bucks or so and easy to install with simple hand tools. You can look online for a video of the rebuild as a reference as well. If you cant start the machine on instant start check for spark. If you have no spark you probably need a new coil. Also easy enough to do with a reference video. But the coil in on the engine inside all those plastic pieces! Good luck and be careful!
