The drum paddles are screwed from the outside of the bowl. To access them, you have to completely strip the machine and remove the wash bowl. The paddles are rarely available as a spare part. You may be able to repair it or remove it. This will affect the wash action to a certain extent if you take it out. Its a big job.
The paddles are normally fitted from inside out of the inner tub. You will have to strip the whole machine down to remove the inner bowl and then you can get to the fitting which holds the paddle in place.
Methinks a manual is the quick answer- for now and probably later!
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
I have exactly the same problem on my ...129 model. I'm a mechanical engineer and looking at the design it apears that these aren't designed to be replaced. The 90 degree tab looks to be only accessed from the outside of the drum so can only lock the tumbler in place from the factory. It needs to be bent flat to get the paddle on!
How to fit Washing Machine Drum Paddle Lifter For all free video help on appliance Repairs visitour Video Tutorials Here's our video guide to replacing a washingmachine drum lifter. A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple. The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out. Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines. There are few types of drum lifter; drum Paddle lifters On hotpoint, creda, Ariston ,indersit and someother makes see video To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine. Huge selections of lifters are available on thewebsite DrumPaddle lifters
until you post the statement again and include such vital details like make model year type of equipment etc and photo then nobody has any idea of what you are on about
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Here's our video guide to replacing a washingmachine drum lifter. A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple. The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out. Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines. There are few types of drum lifter; drum Paddle lifters On hotpoint, creda, Ariston ,indersit and someother makes see video To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine. Huge selections of lifters are available on thewebsite DrumPaddle lifters
