Question about Toshiba Satellite A85-S107 Notebook
Toshiba Laptop Keyboard Malfunction
I have a Toshiba laptop A85 - S107 with an "all but dead" keyboard. It usually does not work at all. The indicator light under the F11 key lights up as soon as you turn on the power. If you run your hand across the entire keyboard some times the light will go off and all the keys will work except the z, the /, and the arrow keys. When you press on of those keys the keyboard freezes up and you have to turn it off to get any further response. A USB keyboard works fine. It IS NOT a problem with the keyboard hardware. My boss has the exact same laptop - without the keyboard problem. I took the keyboard off his laptop and put it on mine. Same problem. I put my keyboard on his laptop and it worked perfectly. I started having problems about 2 or 3 weeks ago. My laptop is 2 years old running Windows XP SP2. I have thought about formatting the hard drive and re-installing everything. Any thoughts?
  • 3 more comments
  • trapper9 Sep 23, 2007
    OK - I made a bootable XP CD using BartPE. I launched from the CD and went into WordPad and I could type all the letters of the alphabet until I got to z. The keyboard locked up. The USB external keyboard still worked fine. It doesn't sound like it would do me any good to format the hard drive and re-install windows. I also ran AV software, Ad-Aware, and Search and Destroy and everything came up clean. Any other ideas? Thanks
  • JrRifleCoach Dec 30, 2007
    I have a Satellite M55-S325 with similar keyboard issues. Keyboard is dead until you start clacking on the keys. The board starts running on with a period or [ then locks up after a time. Replaced the keyboard, updated the bios with like same new, same prob. Any USB keyboard works just fine. Me thinks is time to replace the system board.......Thoughts?
  • nero02 Jun 27, 2008
    same problems as listed.i reinstalled win xp sp2 and it worked for about 2hrs then went dead.help
  • marcosdutra Jul 13, 2008
    I have exactly the same laptop and exactly the same problem. If the laptop stays off for a day, it works well for 15 minutes. If I just reboot after that, it won't work.
    An USB external keyboard works fine.
  • OldHsia Aug 15, 2008
    My Toshiba Satellite has similar problem. A "^" is inserted to each key strock and makes a undisplayable character or a "hotkey". An PS2 keyboard with a USB pigtail has the same problem. I removed the keyboard(s) from Device Manager, unplugged USB, reboot and did not see any difference. Reformated HD, reloaded XP, and updated to FP3 does not make any difference.
    I do not know the procedure to reload CMOS.
    Any ideas??? Please help.
  • 65 Answers
If you boot a XP cd and select repair will it let you type?
Posted on Sep 21, 2007
2 Suggested Answers
6ya staff
SOURCE:
thunderbo611
Josh Levin
  • 75 Answers
SOURCE: my toshiba a85-s107 loads extremely slow at power up
restore it to factory settings
Posted on Jan 26, 2010
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
Need to replace cpu fan on Toshiba Satellite A85-S107 and can not get the laptop appart.
Remove the battery, unplug the unit.
  • Take off the hard drive cover by extracting the two screws that secure it and then taking it off. Take out the screw on the modem and wireless card cover and take the cover off. To remove the hard drive, shift it to the left to disconnect it from the motherboard and pull it out of the computer. Gently disconnect the Wi-Fi card antenna cables and take out the card. Extract the screws on the modem card, disconnect it from the motherboard, and then disconnect the cable to free it from the computer. Remove the optical drive screw, push the drive out of the laptop and then take it off. Extract the 15 screws out of the bottom of the laptop and turn the laptop over.
  • Open the laptop and fold back the LCD screen as far back as possible. Pry up the keyboard bezel (the plastic strip above the keyboard) by inserting a flat-head screwdriver or a spudger in the groove at the right side of the strip. Pull the bezel off the laptop. Extract the keyboard screws and fold the keyboard down over the palm rest. Release the flat cable that connects the keyboard to the motherboard and take the keyboard off the laptop. Remove the screws securing the LCD screen to the back side of the laptop. Disconnect the video cable and the Wi-Fi cable from the motherboard and remove the screws on the LCD screen hinges and then pull the screen off the laptop. There are four visible cables that are connected to the motherboard: the switchboard cable, the speaker cable and the touchpad cable. Disconnect all three. Take out the four screws from the top cover and pry the top cover off by running the flat-head screwdriver along the groove around the entire laptop and pulling it off. Now the laptop is completely disassembled to where the motherboard is exposed as the last remaining component.
May 05, 2011 | Toshiba Satellite A85-S107 Notebook
Toshiba satellite A85-s107 dvd/cd drive has quit working
you should try this start-my computer-right click-manage-device manager -dvd/cd drives-here right click uninstal or update driver.
this should work is your drive in not damage.
Jan 29, 2010 | Toshiba Satellite A85-S107 Notebook
Hi, 2 of the key pads came off at my sisters house can you give me an idea how much it will cost to get them re-installed it seems they are only the top parts & one seems to be sticking
You really can't purchase just the keys alone, you usually have to replace the keyboard itself. My company sells the keyboard for $69.99 for the OEM and $59.99 for compatible keyboard.
Thanks
C2Solutions
Aug 01, 2009 | Toshiba Satellite A85-S107 Notebook
Howto remove key board of Satellite A85-S107
underneath the laptop you will see three or four screw holes with an arrow on them in the centreish of the laptop. remember the keyboard is only in the middle of the laptop and not the edge so no need to undo any more.undo these and open laptop. you should also see two small lumps at the foot of the keyboard either side of the spacebar but lower. this shuold release the main body of the keyboard and allow you to lift as far as your ribbon wire will allow. carefully undo the very small catch at the foot of the ribbon wire and release the wire. don not under any circumstances snap this wire as it will be a very skillfull soldering job to repair the damage.
Feb 06, 2009 | Toshiba (225EXTR5)
Keyboard replacement
Hello this is for uprading the memory , But does show how to remove the keyboard
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A85/replace-laptop-memory-1.htm
Good Luck .Joe
Oct 07, 2008 | Toshiba Satellite A85-S107 Notebook
Toshiba Laptop Keyboard problem
My Toshiba Satellite A45 S120 keyboard has a problem, some of the keys are not working. When you type it does noting. Sometimes when you start the computer, it continuously types the letter eeeeeeee. You can hit some keys randomly and this will stop, but if you start a program (eg. ms word) the same thing happens.
Sep 05, 2008 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite Windows XP Keyboard problem
First and foremost I would reseat the laptop key board cable/edge connector.
I would replace the MOBO. It is unlikely that it would be the Bios or the Keyboard.
Aug 15, 2008 | Toshiba Satellite A85-S107 Notebook
Satellite a85-s107
do you have restore disc that came with laptop if you use this to reformat coputer yes it should help
Jan 15, 2008 | Toshiba Satellite A85-S107 Notebook
Toshiba laptop key not working
Well if its under warranty i advice that you get the keyboard replaced(its covered under warranty)
If it is not under warranty you can use an external USB keyboard as an alternative..
The best cost-effective solution is u can get these alphabets by the following method press and hold alt then press the following numbers:
66-for-B
67-
for-C
86-
for-V
98-
for-b
99-
for-c
118-
for-v
Oct 29, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A85-S107 Notebook Logo
2,025 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
