Question about Swisher 44-Inch 12.5 HP Trailcutter #RTB12544
Blades won't engage - Swisher 44-Inch 12.5 HP Trailcutter #RTB12544
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Blades won't engage on sears lt2000 riding tractor
check the transmission beltfor tension also the deck belt
Aug 13, 2012 | Sears Garden
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
John Deere SST16 PTO won't engage mower blades
check for power at the clutch if no power check the safety switches and the switch itself
Apr 23, 2012 | Garden
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Swisher 44-Inch 12.5 HP Trailcutter #RTB12544 Logo
149 people viewed this question
Top Swisher Garden Experts
dannydoesita
ray gallant
George Merkley
George Merkley
Are you a Swisher Garden Expert? Answer questions, earn points and help others
