Question about Homedics PS-200 Iron with Auto Shut-off
Plugged in, reset button is lit, won't go off
I have a home touch garment steamer. I plugged it in, the on/off switch is lit, and the reset button is also lit. I pushed in the reset button, but it doesn/t do anything. Usually when I pushed the reset button, it went off and it was ok to use. What can I do?
Thank you.
    New Friend:
The problem is the thermostat (NC 150 C). A replacement is available at Digikey.com, item R2015025 (part no. 317-1468-ND) It's a simple replacement with the bottom removed.
Posted on Nov 10, 2009
  • Tom Fontana
    Tom Fontana Nov 09, 2017
    That really isn't the correct replacement because it does not have a reset button, so it will automatically reset over and over. here is the replacement part that duplicates the original. Part number 05EN1034(150/C), stock number 68C2874 at Newark.
  • Anonymous Aug 21, 2019
    I cant find the part on the website, can someone send a link to it please.
    New Friend:
As crazy as this sounds, I had the same thing happen to me and I couldnt fix it, and I was about to throw the steamer out until as a last resort i hit the base of the steamer really hard right on the reset button with a shoe, and Voila! it worked. Now every time I want to steam i have to smack the reset button really hard, pressing it does not work. I dont know how long this will last, but at least I can use it now!!
Posted on Nov 09, 2009
  • Gabriel Ortiz
    Gabriel Ortiz May 21, 2018
    That advice was solid gold! Worked EXACTLY as stated. Will hit base with shoe again.
    New Friend:
  • 19 Answers
The thermostat is the problem, I used aew3656's solution and took care of the same problem on my steamer, just take out the damaged thermostat and use it as a sample to get a new one from any electroncs supply store, BTW dont forget to buy thermal grease, it helps dissipate the heat so your steamer won't overheat, and the thermostat wont't go off every 2mins.
Posted on Jun 02, 2010
    New Friend:
I read all the above commments. My steamer reset button wouldn't work so I hit it with my hand rather hard right over the reset button and steam started right back up!!! Weird!!!
Posted on Apr 05, 2011
    New Friend:
We opened it up and it turns out that from using regular tap water and letting the water sit long after use, the wrong parts have gotten so badly corroded that even if the thermostat was replaced, the wrong parts would still overheat and the reset button would kick in anyway.
A friend did something so that it no longer registers with the thermostat, so it should be usuable again, with a lot of caution though!
So now, I can use it again for short periods of time, with distilled water and promptly turned off and unplugged immediately after and water removed when not in use.
Posted on Nov 21, 2010
    New Friend:
Mind did the same thing.....just stopped working. Remove the hose and pour CLR or Lime Away in hole also pour some in hole where water tank goes. Let sit overnight and flush out. Then buy yourself a large bottle of distilled water for future steaming.
Posted on Jul 15, 2010
    New Friend:
THANK YOU everyone! I needed to smack the reset button lightly with a hammer and that worked. It is now working once again.
Posted on Aug 04, 2010
  • Gabriel Ortiz
    Use shoe.. a hammer is rather hard.
    New Friend:
Jus remove thermostat, remove rust on both parts, set thermostat back and ready, it worked on mine. Dont forget umplogge the power cord first.
Posted on Nov 28, 2014
  • Judy Taya
    Judy Taya Mar 24, 2017
    Thank you Saul! I took the thermostat apart and there was salt between the thermostat and the contact point. I have a water softener and salt built up and clogged the reset button so the reset button stayed on. Once I took it apart,scraped the salt and minerals from both contact points and figured out how the reset button worked it worked! From now on...only distilled water and I'll empty it when not in use.
  • Michael Deaver
    Michael Deaver Sep 07, 2017
    Saul, thanks for your suggestion. This worked for me. There was lime or scale build-up preventing contact on the underside of the thermostat/auto-shutoff switch. we will only be using distilled water from now on. I do not believe the instructions suggest it.
    New Friend:
Im smacking as much as I can lol, it aint working haha!
Posted on Feb 13, 2016
    New Friend:
I've been cleaning mine all night with vinegar and water like the manual said. Still didn't work. Saw that the reset light was on and couldn't get it to go away. Smacked it with a shoe works perfectly fine!
Posted on Jul 30, 2015
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Sorry I hit the reset button w my slipper couple times reset it and it works my daughter happy
Posted on Feb 28, 2015
Anonymous
SOURCE:
My handheld Conair garment steamer is heating up but not producing steam. How do I fix this?
A handheld steamer uses hot steam to relax the fibers in clothing. A jet of steam is directed at the cloth suspended on a hanger. A steam wand at the end of a hose is held a short distance from the cloth - providing a smooth look without the application of scorching heat to the clothing.Steamers are ideal for soft and delicate fabrics like silk, satin, polyester and jersey. Because a garment steamer does not actually touch clothing - there is little
May 03, 2018 | Conair Irons
How do you clean a Home touch PS 250B clothes steamer?
I have a hand steamer and use it every time I wear a garment that's a wrinkle-magnet. Usually it does the trick but I may have to steam it for five to ten minutes. Floor steamers that are often used in department stores have a larger capacity water tank and tend to be the most effective. But they also cost a lot more than a hand-held steamer.
Jan 13, 2017 | Irons
Clothes steamer won't steam home touch
The steam not only removes wrinkles, it freshens the fabrics - making them look cleaner. You can use this steamer on clothing, bedding and table linens and also to remove.
Jun 23, 2014 | Rowenta Commercial Garment Steamer - White
Rowenta garment steamer is 9100 lights up but no steam
Look at the manual again maybe theres a button that you have to turn on. Or call the nearest repair man maybe he knows or can tell you.
Dec 26, 2012 | Rowenta Commercial Garment Steamer - White
ROWENTA IS8050 INSTRUCTION MANUAL
Rowenta IS8250 Garment Steamer instructions are no longer available from Rowenta.
May 28, 2012 | Rowenta Commercial Garment Steamer - White
MANUAL FOR PS 350 HOME TOUCH GARMENT STEAMER
First-time ever used. Water filter installed. WON'T STOP BEEPING AND START STEAMING.
Mar 03, 2012 | Irons
Need a User Manual
my home touch ps200 has the reset button that wont reset ?
Oct 10, 2009 | Irons
I have a panasonic unwrinkler garment steamer. how does it work
Friend has exact same model in the box with instructions and help centers repair numbers. Do you still need help? Want a new hardly used 1?
Oct 07, 2009 | Conair Compact Garment Steamer Iron
How to use a steamer.
  1. Plug in the steamer.
    • The steamer usually comes with a smallish padded square with a strap that slips over your hand. (If you so not have one of these, cut out a square from some stiff cardboard, pad it using cotton batting, and cover it with a heavy, smooth, waterproof or water-resistant material.)
  2. Make sure it is steaming nicely before you use it. You check by pulling the little trigger on the handle, and seeing how much steam issues when you release it. You actually want to use this while steaming as well, in order to release more steam when needed.
  3. Hang the garment, and slip the padded square over one hand.
  4. Place the hand with the square on the underside of the garment, and use it to keep the fabric smooth while you steam it.
  5. Use the steamer by holding the nozzle close to the garment, and pulling both it and the padded square in downwards strokes.
Sep 18, 2009 | Rowenta Commercial Garment Steamer - White
On and off petal switch not working
When I took mine apart I noticed the switch had melted near the contacts. This makes me not want to fix it, but instead, look for a better model. Hope this helps.
Jun 10, 2009 | Rowenta Commercial Garment Steamer - White
Homedics PS-200 Iron with Auto Shut-off Logo
27,646 people viewed this question
Top Homedics Irons Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Homedics Iron Expert? Answer questions, earn points and help others
