Not the correct battery type.
Try here Support Cobra Electronics Corporation
SOURCE: cobra pr 3850wx bought new NiMh 800mAh 1.2v
Regards,
Tony
The higher capacity batteries are fine (they'll just take longer to reach a full charge), the problem is that the original batteries have the negative contact extended as a band around the bottom of the battery. The charging tab at the bottom of the unit makes contact with the negative end of the first battery through a springy contact inside the battery compartment that touches this band. You don't have to buy expensive Cobra batteries. The easy fix is to wrap some aluminum foil around the bottom of the battery that touches the springy bottom side contact. Be sure the foil also covers the bottom end of the battery), or you could cut away the outer plastic battery cover (at the bottom) to expose the metal shell like this: http://www.walkie-talkie-radio.co.uk/replacing-cobra-walkie-talkie-rechargeable-batteries.html
