My local disk drive is cannot accessible. when trying to opren(click) the dive the text box shows access denied. How this problem can solve?
This occurs when the drive was taken from a PC where someone made the drive un-shareable.
The fix in XP:
1. Turn off Simple File Sharing, via Explorer, Tools, Folder Options, View, (NOT) use Simple File Sharing.
2. Now when you right click the drive letter for the drive on the new PC you will see a Security tab (made invisible by Simple File Sharing).
3. On the Security Tab, add yourself or any user, and grant Full Permission.
4. Now you can Explore the drive like any other.
thanks for this solution, I got very very important drive back..........
i've the same problem.i was copying game files to my local drive E but suddelny electricity went off for a while after when it came back i opened my computer re-copy my game files but at the sart screen window repaired my local drive E and after it when i opened mr L.drive E this message came That Access denied.i tried to explore and also tried open it with run but it did not work.
Solved !
The problem IS, after all, 'Permissions'.
Permissions need to be set, not only under 'Sharing', but more importantly, 'Security' / 'Advanced'.
On the system that your MyBook was originally installed on, right-click the folder on the drive which you wish to permit access to from other systems, select 'Security' and select 'Advanced'.
Create a new user 'Everyone' and give 'Full Control' to this new user.
The drive will then be available on other systems as mine now is.
Phew!
Thanks Dude.The advice worked.Cheers....
Thanks alot after hours of googling and changing admin, running replace current and doing change owner on cmd your advise worked :)
thnx it works
same here, hours of looking around until i did this. Thanks cyberdyne!
same here, hours of looking around until I came to this post, and it worked... thanks cyberdyne
Hi , got the problem with my maxtor hard drive
error message is
.D:\ is not accessible
Error performing inpage operation.
done the virus checks driver updates,system restore but nothing works, comp is very laggy when trying to use it, tried turning the power of to the D drive and that fixed the problem with the lag but no cant get into my back up drive which is the D drive.
plz help if u can
Right click on d: go to properties
click on security
click on your user name in the upper window
and in the lower window select all chek box allow
click on apply button then ok
it will work definitely
Try Running scandisk else if failed Go to Command Prompt (Start>>>Run>>>cmd) then enter the following Convert D: /fs:ntfs /nosecurity Hope this helps
Yes I have the same problem: "access is denied" when i try to delete or move or do anything in local disk D. I just installed windows again and forgot to format it. Earlier solutions could be helpful but when i open a files properties, there are only general, sharing and customize. No security. I'm administrator so what the ****? Also "1. Turn off Simple File Sharing, via Explorer, Tools, Folder Options, View, (NOT) use Simple File Sharing." that one is missing. No "use simple file sharing".
Me too have the exactly same problem...
and ihave some important data in my d drive...
plz plz help me...
mail me d solution: [email protected]
Hi
i have one problem
when i wasn' t at home my friennd open my computer and he locked my E local drive there is imporatnt files for me so please help me . and he wasn' t at here so
solve this problem
the message is access denied
but other drives was open
Ram kc
My drive c and drive d cannot open
Try formating the drive from dos promt
Right click folder/Owner tab/select the admin owner profile (Maybe your same profile)/check replace owner on subcontainers and objects...waaala! Enjoy... Post helpful....Sincerely Mytek
Hi, everyone I have a Solution for the any HDD drive not accessable. Any problem can be solved only when you also face that same problem in life. I also face this problem with myself. I have 2 hdd on my pc one is Hitachi serial 80gb and other is Maxtor sata 250gb.I have Windows Xp Sp3 on C:/ drive and Total drive from C:/ to J:/.C,E,F,G are my hitachi and D,H,I,J are my sata drives.One day due i was working on my pc and suddenly power went down and my Ups also didn't give the backup on that day. When Power came back i was totally shocked to se my 3 drives H,I and J are not accessable. All 3 are showed raw in their properties.These 3 drive are of my sata. And then i installed windows 7 Ultimate in my d drive that is also of my sata. After login in windows 7 my all drives are working fine but everytime on boot from any windows of mine these 3 drive are checked by chkdsk on everyboot. I can see all my drives in windows 7 but not in XP SP3. Then i login from windows 7 and attach a external drive of 160Gb in it i start transffering data from H,I, and J drive one by one. Then i formatting the all 3 Drives H,I,J one by one. After it I again tranfer all drives respective data to them and thats it. It starts working fine on both windows and now the error of disk check by chkdsk on boot also disappear. Now my whole data works fine and my Hdd are also fine. This method works for me. If anyone get it helpful or wants to talk further about it contact me on my mail EJAZ89(@LIVE.COM. Because i'm not a regular user of this website.
Your Friend
Ejaz
MCSE,CCNA,Networking Student
[email protected]
See solution #8, from explorer, right click the hard drive and properties, and in security tab, click full access for system & users. it worked. thanks mate
Two more steps to solve your problem click on below link (solved)
http://digissofts.blogspot.com/
http://www.digissofts.com
When i set a new window xp i forgot set my drives( D )
I have the same problem too, but mine one is a new disk drive appears after i've downloaded some programs. and i cant found it in computer management or anywhere in solution from 1 to 18, it just appear on MY COMPUTER, what can i do?
As solution #9 stipulates it has everything to do with rights. I too had the problem, and I just went to Security/advanced and added the current user and gave full control. After adding this security setting my drive was accessible again.
A corrupt or missing boot sector will cause such kind of problem with the following indicates:
*Invalid media type reading drive.
*Abort, Retry, Fail?
*File system is displayed as "RAW".
*Windows may ask if you want to format the drive, such as warning "disk not formatted. Do you want to format now?"
*File names contain "weird" characters.
"Sector not found" messages.
To fix the boot sector, you may refer to
http://www.ptdd.com/fixboot.htm
If it still cannot be solved, you have to recover all the data out and then format the partition as the system indicates so that you can enter the partition again.
http://www.easeus.com/resource/recover-raw-disk.htm
Still having the same problem!!----------
I have tried all of this and just can't get it...either I am doing it wrong and its not working???I went through the security tabs making sure it was set to give me permission. even added another user and gave them permission, it starts going through the mybook files and then stops because it ran into a problem, forcing me to cancel.
if I start up in safe mode, its there and I can get into it...so that tells me that ITS THERE. there is one folder missing. Its my picture folder. but judging by the amount of space that it says I have left on the drive, I'd say that its still there, just didn't load up in safe mode for some reason. I don't know what else to do. thanks, shirley
Ok here's the best solution to solving biggest problem with maxtor hard disks.... there 's nothing u can do about it so get a friends hard drive equivalent or more to the space of your hard drive(empty) and then use the easeus software to recover all files from it and then format the hard disk all over. its pretty simple and it worked for me!!!
Easiest solution-
Open command prompt (admin)-follow these steps:
in cmd,type- chkdsk /f (your disk):
EXAMPLE-IF MY D DRIVE IS NOT ACCESSIBLE,THEN
chkdsk /f d:
my blog- gamersstuff123.blogspot.com
This solve the issue....at all the lasting solution is to reinstall OS by formartingbut YOU HAVE TO BACKUP YOUR DATA...to get ur data plug the drive as slave to another working pc and backup the data.....also this will not last long.....all you need to have is the new HDD
You must check your account if you are admistrator
try on :c right click, than click properties,than click above on
security than check for any change you may had made recently
on the account access,put the admistrator account back again
and any other users that you might had changed recently,or
made them off the account.
I had that problem and it was because of puting off an administrator account and the users of it.
Question: Computer Local Disk (D:) D: is not accessible Error performing inpage operation youtube
Hey friend you can go to https://plus.google.com/u/0/105276208727413473827/posts to get one, you can find all versions of product keys for windows, it works well and the price is surprisingly cheap!
Activate windows click here: www.acyberkey.com
you can find the keys you want in a low price that you have never imagined.
You can recover your hard disk by going this link http://www.techppp.com/2013/08/how-to-recover-data-from-dead-hard-drive.html
You can recover your hard disk by going this linkhttp://www.techppp.com/2013/08/how-to-re...
Plz plz help me my local disk f is no accessible but way
This error appears when attempting to access the Shared Documents folder (which appears to be renamed to “Documents”)
I recently had this problem on the main computer here at my home. This same problem prevented Adobe Acrobat 6.0 from working, and prevented a reinstall (or uninstall and install), as well.
I’ve finally found a fix. And it’s quite a simple one. Follow these steps.
1. Choose Start > Run, type %allusersprofile% in the Open box, and then click OK.
2. Right-click the Documents folder, and choose Properties.
3. Click the Sharing tab, and then unselect “Share This Folder on network” if it is selected. If it’s not selected, select it.
4. Apply. If you had to unselect the box in step 3, now select it again and Apply.
This causes the name of the folder to change to Shared Folder.
When do u click mouse2 on local disk it appears "Open(O)" try using explore option. Mouse2 -> Explore
You can just create a shortcut of the drive the open the shortcut..
it worked for mi, hope it wil help u too..
THANKX..
To fix this i just right clicked my laptops main hard drive, clicked the properties option, then clicked the security tab (moved that window to the side)
(Went back to my computer)
Then I right clicked the External Hard Drive, clicked the properties option then clicked the security tab and made sure everything was mirrored (the same) and the boxes check were all the same.
It worked for me although every time i clicked a folder in my external it said i did not have permissions but to click "continue" and i would have them from now on. Did have an issue when i right clicked the external drive a window would pop up saying my Recycle Bin in F:\ was corrupt and if i wanted to empty it. I just click no every time.
I try the solution via command prompt but there was a massage "access denied".The problem still remains.
more information about the problem:
I can access the drive in safe mode.In normal mode I can't. Also my file system was fat32 after the problem occured file system is indicated as RAW. please help me to solve the problem
h:\is not accessible
please help
d:\is not accessble access denied
when i access my d: drive, it is asking "format now" what can i do?
I have tried everything to try and get my local disk (D:) but without any success. Would it be because I have now a new computer ? Or is it that the technician who transfered everything from my old computer to this one did not do something necessary ? Please help because I had all my photo folders in My local disk (D:) and now I am missing them.
D: access denied
F: access denied
E: access denied
Whenever I try to save anything to my D: Drive it says that it is not accessible. Can anybody offer a solution.
p.s.
Please reply in plain language
i can't access my local hard disk (c: drive) i did'nt try anything to do because i'm affraid..i might delete important files on it so i did'nt do anything..now i'm having so much problem with it please give me some solution on how i can solve this problem without deleting any file(s) on it..i just want to know how i can access and retrieve my recent documents on it..
MY d
i can not find the local disc d where all my documents are till yesterday i could can you give me a hand?
I cannot open my local disk directly
It shows to choose a program from a list
Local Disk(D:) is not accessible Access is denied problem,
when click on my hard disk it says the file or directory is not accessible
I have three drives in my external hard disk I can't access 2 of them earlier I was able to access all of them.
Local Disk(D:) is not accessible Access is denied. this is the problem mee too got..plzz help me
wen i duble clik on my local disk ,a dilog box of "open with" appears , wat's the solution of dis prob????
was playing cs while playing rock songs. he volume was very loud when the screeming part shows so i tried to lower the volume the my computer got jammed. so i hold the on button so it can turn off quickly. after leaving it for like 1 minuite having a thought that its safe. then i tried to search my songs in the local disk D a box appeard. it says"THE DISK IN DRIVE D IS NOT FORMATTED,do you want to format it now?" so please help me to solve this problem. im currently using windows XP
I have the same problem. I can't access D and can't play my CDs. Please help.
my local disk (D:) just isnt showing up when i click on my computer. because of this, i cant download itunes or burn cds. its a requirement for itunes AND I DONT HAVE IT!!
hard drive not recognicing
yyugjghgjgjghjgjgh
this oprationhas been canceled due to restastions in infeeted on this computer plz. contect system administrator
My local disk is not opening. when i click it 'open with' dialog box is comin. somebody help me to correct this problem
If I log on to administrator, and try to install any programm it denies me and if I try to go to system restore it also denies me. I am using windows vista.
please help me solve this prplem
local disk drives is not found when i attempt to open files from winamp or sonique or anyother... what might be the problem?
when i open my local drive (f:) it shows that drive is not formatted, do you want to format it now.
so how can i access my data, i can't format it
my file system previously was fat32 now it shows RAW
so if you got the solution please help me
Hey folks. (WD 7500AA Problem - type Western digital external drive)
until today my external hard drive worked well.
But today some big bad surprise
a) the western digital harddrive appears - take a while but...appears
b) the hard drive is not accessible.
c) if i click on properties
d) run the computer management -> Device manager -> disk drive...the drive is there to. I click on the drive tells me device is working properly but doesn t identify any volume size on the Tab.
e) I run the diagnostic LIFEGUARD but following erro occurs >Quick test on drive3 not complete-status code 07 failed read test element - failure checkpoint 65
I
Quite desesparate, having this harddrive pbm.
It s as I went to the bank every week, putting my money safe and one day you see there is nothing anymore...! Everything lost ?
Have some pics of my small kids on there I ll never can show him when he is growing up....(tears tears tears)
Hope some genius come by and give me a magical solution....!!!
when i double click my external hard disc, it shows access denied. as well as, in doing right click > open, it also shows access denied. I can only open my files inside the external hard disc when it auto play. Pls help
my local disk drive is cannot accessible.
my local disk d:\ is not accessible
my self kirit patel
i have also problem
c is not accessible access is denied
Dear team,
yes i have the same problem.
plz assit me
thanx!
WD MyBook Homne 1TB here. Works fine from initial system but 'Access Denied' from 3 other systems. Permissons on all files set to 'Everyone' / 'Full Permissions'.
Have contacted WD and they are still trying to blame my 3 other systems after 8 emails, rather than admitting there is a problem.
local disk d is not open and no access , not dos base show plz solution
my hard drive is not booting up can not access bios keeps aking for password can anyone help thanks
I have the same problem , but I can access Local Disk D by "RUN"
You just write D:\ and it will be open
when i try to open my d: on local hardidk a messege come thta show that the drive is not formatted properly formatt it..also in cmd i cannot access d: drive.. my windows is in drive c its working plz help i dont want to lose data by formatting....
I have a WD MyBook external hard drive. Have all my old PC data on it and was using it with minimal problems for the last 8-9 months, now all of a sudden "access denied" I've tried several suggestions online in regards to permissions and ownership etc...nothing has worked. It still shows up in "my computer" and properties claim "device is working properly" yet I can no longer access my much needed files.
my d;\ drive is not accessible please help me..
